Old 10-17-2018, 02:13 PM
MC FEVER's Avatar
MC FEVER MC FEVER is offline
Boat: 93 Prostar 205 LT1
Question TACHOMETER - What do you guys think?
The last week of the season my tachometer began to read incorrectly, but I noticed that the RPM's on my Perfect Pass display appear to be correct. 93 LT-1
Gauge failure?
- I'd rather be SWERVING!
Old 10-17-2018, 03:38 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 PS 205-351w,285HO
Gauge failure?
My '92 has the same issue (351, not the LT-1).I also assumed gauge failure for the original VDO tachometer.
I checked connections on back of tach and the 4-6-8 switch on the back as well with no luck. It still reads incorrectly (low). Perfect Pass RPM's are correct.
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 10-17-2018, 05:10 PM
Nick.W's Avatar
Nick.W Nick.W is offline
Boat: Mastercraft, Prostar 190, 1993, LT1, Limited
I had the same problem with my 93 LT1 tach. Replaced ground and cleaned all ground connections to back off gauges and that fixed it. 25 years those nuts have never been off, there was a layer of something on them enough to effect the ground.
Sent from my XT1650 using Tapatalk
Old 10-17-2018, 09:39 PM
Prolly corrosion.. get an automotive multi meter chk rpms of (should be) gray wire on coil pack
