  #51
Old 05-26-2014, 10:36 PM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: 2015 X20 SS
Originally Posted by teamcanada View Post
Any updates here? Bump
I think MC has his Boat now....
2015 X20 SS GEN2 6.0
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 05-27-2014, 01:42 PM
hughes26 hughes26 is offline
Boat: 2013 X-30 6.0L
Short and quick update..
I got my boat back from MC on Friday. I was not convinced that the changes they made would make a difference but it did. I now have a boat that does not list while cruising, surfing or wakeboarding.
Old 05-27-2014, 01:54 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
.... what are the 'changes they made'?
Old 05-27-2014, 02:07 PM
They added a "hook" to the rear starboard side. MC said it was supposed to be there and mine was not, or it was not enough. They also added some lead to the transom on the port side.
Old 05-27-2014, 02:57 PM
bobx1 bobx1 is offline
Boat: Was 2007 X1 - now looking
Originally Posted by hughes26 View Post
.....They also added some lead to the transom on the port side.
Mastercraft added lead???
Old 05-27-2014, 03:08 PM
ttu's Avatar
ttu ttu is offline
i was thinking the same thing! sounds more like a bandaid..
Old 05-28-2014, 03:20 PM
MC gave this explanation - No 2 boats come off the line weighing the exact same. Each boat is hand laid in the molds which can allow for more material in this boat compared to the next boat. With that said each individual boat could have more laminate on one side of the boat than the other. Causing a weight difference Port and Starboard.
I have toured the factory (strongly recommend it if you are ever close by) and have seen them lay the molds and can completely see where a little more or a little less material can get applied.
In the case with my boat they added 100lbs of lead to the Port transom. They did a great job and you cannot tell it was added by looking at it. I did not think this would resolve my issue but it did.
I am just thankful that they stepped in and made everything right and they did it with little fuss from me. MC took this on and made me a happy customer again with a proper riding X-30. I had Band-Aid on my brain to when they 1st told me. Then I looked at it in a different way. Owners are adding lead to their surf boats all the time and they are just laying it in the boat some where. At least mine is installed properly and without me telling you you would never know it was there.
Old 05-28-2014, 04:22 PM
awesome story of getting taken care of.
Old 05-31-2014, 04:12 PM
Quinten Quinten is offline
Boat: 1997 Crownline 182 (sold), 2012 Mastercraft X2
That is great news.
Do you have a picture?
Old 07-13-2014, 11:05 PM
LD50 LD50 is offline
Boat: 2013 X10
I'm glad I found this thread. Just purchased an immaculate 2013 X10 that was very well taken care of. I didn't notice anything on the test drive mostly because the cooler was empty and there were always 2 people sitting port side. I've had it out a couple of times and noticed a heavy lean to starboard and it seems to ride pretty nose high even with the plate down. I'm coming from a Supra 21v which did list a slight bit to starboard but was only noticeable from looking at a slight difference in the wake from side to side.
My boat only has the center plate and no tabs. Confirmed the ballast was empty by cycling the drain pumps while not moving and again when sitting at an angle on the ramp. I notice mine listing enough at around 21 mph that if I make a moderately hard right turn, the rub rail is near the water line and it will kick spray up until it hits the wakeboard in the starboard rack. It doesn't do this if making the same turn to port. I'm starting to wonder if I may have made a big mistake by upgrading. I love this boat and it's obvious to me how much more thought was put into the design but this worries me.
