  #41
Old 04-30-2014, 06:03 PM
mitchelmilitiapres mitchelmilitiapres is offline
Boat: Family Boat '08 X-Star
After taking a second look at the photo, it does appear that something is dragging. Potentially a wake plate, but unfortunately there is not safe way to test this.
Old 04-30-2014, 07:16 PM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: 2015 X20 SS
Originally Posted by MattsCraft View Post
OK - So this is a 2013 - Was it purchased new, original owner from the dealer??? Every boat that leaves the factory is water tested, no way this should leave the factory like this. This is not a slight list.
IMO - If this boat was purchased as a new boat from the dealer, rather than all the guessing, I would drop it off at the dealer, tell them you will pick up the boat when it is fixed. If it takes them much more than a week, this is prime season, they would be lending me a boat until this is fixed.
I hate hearing stories like this, my dealer is great, personally delivers every boat on the water, they would not let this leave their shop and would be on the phone to MC immediately.
He has been working with the Dealer AND MC for Some time on it.
You are right, they should be all over it....it would drive me nuts too.
These Boats are thought to be of the Very best....Im sure MC will set in/up and rectify...
Sad part is , many of these dealer are small outfits, and there shops are backlogged with Work...
Drop a boat off today....loose it for a MONTH!!!
2015 X20 SS GEN2 6.0
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 04-30-2014, 07:26 PM
Mastercraft13's Avatar
Boat: 2013 X-10 6.0
Originally Posted by FourFourty View Post
Every inboard, that I have ever owned, has tilted to starboard while under way, (if I am the only one in the boat, or only have one other light person on the port side) The prop rotation causes it, along with the additional weight of the instrument panel, and all the other additional weight in the helm. It's the same reason that they have the little optional port ballast tank in a pro-star to balance the boat perfectly, while under way.
I have a 2013 x-10 and I have this issue also, I just throw a little weight in the rear tank at its fine. Just seems to be from prop rotation.
Old 04-30-2014, 10:03 PM
Nordicron Nordicron is offline
Couldn't u just temporarily unplug the actuators while they are in full up to make sure it wasn't one of them acting weird? Otherwise I'd perhaps it was weight in a tank.
Does it do this when everything is full also?
Old 05-01-2014, 08:27 PM
masterx10 masterx10 is offline
Boat: 2014 Mastercraft X10
I also have this issue on my X10 but is only noticeable when I have the centre plate at 100% for beginner riders, I usually lower the starboard Gen 1 surf tab to level the boat. When the plate is all the way up, the issue appears to be not visible.
Before I started using the surf tab to level the boat and with the attitude plate at 100% I had one rider cutting out to port side and the boat would still lean to the starboard side. Does this sound right? As this is my first Mastercraft I was not sure if this is normal or not.
Old 05-07-2014, 10:22 PM
hughes26 hughes26 is offline
Boat: 2013 X-30 6.0L
lashburn1 just wanted to let you know that my boat is heading back to the MC factory for their engineers to go over the boat and give a resolution to the issue.
Old 05-08-2014, 01:56 AM
lashburn1's Avatar
Boat: 2015 X20 SS
Wow!!! That's a big beal???
How long will you lose the boat???
Do you get a loner?
At least they are taking the problem serious .....
I hope this thread drew the attention it needed
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 05-09-2014, 07:44 AM
Do you get a loner?
Not sure why they all of a sudden took interest but they did.
They said it would be a quick turn around with a decision or solution.
My dealer has me a loaner boat waiting on me.
Old 05-09-2014, 11:53 PM
lashburn1's Avatar
Boat: 2015 X20 SS
That is awesome,
Great to see both Mastercraft and
the dealer stepping in to rectify the situation.
You bought a brand-new boat from a top quality manufacture.
Nice to see you have a boat available during your fix!!!
Who is your dealer?
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
Old 05-26-2014, 03:53 PM
teamcanada's Avatar
teamcanada teamcanada is offline
Boat: 2013 Mastercraft X30
Any updates here? Bump
