Old 03-31-2007, 02:22 PM
Hrkdrivr's Avatar
Hrkdrivr Hrkdrivr is offline
Boat: MasterCraft X-45, 2006, L18, slate gray/white
Question Trailer brakes clunk
When I was "test driving" the boat/trailer combo yesterday ('06 X-45), the surge brakes clunked pretty loudly while braking and then again while accelerating, like somebody hitting the hitch w/a hammer. The brakes seemed to work OK and it didn't seem to be a problem, just annoying.
My previous trailer's surge brakes made no noise at all.
James said this is normal for this type of trailer brake setup, but I seem to remember reading somewhere the brake fluid reservoir might be low or the brakes might need to be adjusted.
What have the rest of you experienced? Do you hear the clunk every time the brakes engage and disengage?
Old 03-31-2007, 02:30 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
I hear it too, to some degree in the same situations.
'04 MariStar 230VRS/MCX
Old 03-31-2007, 03:45 PM
sand2snow22's Avatar
Boat: Ri257
We have it to some degree as well, I greased the ball and this really seemed to help. Also helps when at a stop to move slightly forward to disengage the brakes, then when you accelerate it won't happen.
It may also be the big pin on the hitch, make sure it is nice and tight......
We'll make it a little nicer....
Old 03-31-2007, 03:49 PM
Hrkdrivr's Avatar
WOW...posting FOUL! Erk, over to you for the fireworks.
(thanks for the replies)
Old 03-31-2007, 04:38 PM
That is exactly right, just let off the brake and accelerate slowly at first. I love the trailer brakes on my MC, the boat actually stops my truck.
___________________________________________
Myself I'll live on the edge and surf without a helmet.
Old 03-31-2007, 04:49 PM
Mine too. The problem is that it also tries to stop my truck periodically as I'm driving down the highway with the trailer unloaded.
Old 03-31-2007, 05:09 PM
trickskier's Avatar
trickskier trickskier is offline
Boat: In Search Of...
From my experience, the clunk when you accelerate from a standing start is normal. I do as others have mentioned and accelerate slowly.
If you can feel a clunk when stopping, I would suggest checking your brake fluid level and consider bleeding the system.
Good Luck............
The Only Thing That You Can Give and Still Keep Is Your Word
Old 03-31-2007, 05:21 PM
trickskier's Avatar
I get a lot of wheel hop trying to stop when tandem trailer is unloaded.
Old 03-31-2007, 05:25 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
The clunk when taking off is the hitch portion of the actuator disengaging from the mastercylinder and the forward dowel hitting the end of the slot it travels in. A clunk when slowing down, should not normally happen and may be a result of no fluid or low fluid level in the mastercylinder or the shock absorber in the actuator has become weak and or has failed. The serious clunking while towing empty is the trailer basically bouncing around doing what it wants to, because the weight of the boat is what makes the brakes work as they were designed and that is with a load. If you trailered around all the time with the trailer empty, there isn't enough weight back there for the trailer to need brakes.
Disc brakes do not need nor do they have a way to be adjusted, outside of keeping the mastercylinder properly filled.
Charter Member Number 1
Quote: 2RLAKE,
Old 04-02-2007, 09:41 AM
Hrkdrivr's Avatar
Thanks Numero Uno...I'll have them check the fluid level and the shock absorber BEFORE I take delivery...TOMORROW!!! WOOHOO!
