Old 11-27-2017, 02:00 PM
Originally Posted by EGRAY View Post
Waterski.com is the closest I have found so far... not looking good...
I have an email out to Carling with a photograph of mine. I'll let you know what I find out.
Even if you had to swap them all here is a close resemblance that would fit the panel. ==> https://greatlakesskipper.com/carlin...minated-16-amp <==
John 3:16-18
Old 11-27-2017, 02:12 PM
EGRAY EGRAY is offline
Boat: 1993 205 prostar
Awesome!! I just checked there web site and did not find it... My Mastercraft dealer in GA says he has them but only in red or blue light... not the green that I have.. I will post if I can nail it down as well.
Old 11-27-2017, 04:43 PM
88 PS190 88 PS190 is offline
I did this on two separate boats this summer - both the 88 and 94 had burnt bulbs, the 88 had a bad rear bulb socket - this caused me several problems, the first was I couldn't get my voltmeter down into the hole on the hull so I tried to read voltage at the mast head - which didn't work.
This lead me to believe I had an actual wiring/fuse/switch problem that I spend a good hour trying to troubleshoot before grabbing the mast from the other boat - which worked with a new bulb.
The bow lamp then was simply a bulb on both of the boats. I did replace my stern bulbs with LED versions - mostly because at idle with all the lights on they go dim and the LED is way brighter.
Old 11-27-2017, 08:40 PM
Testimony as the voice of reasoning....twice in this thread.... I'd check the bulbs...
Bow bulbs
John 3:16-18
Old 11-27-2017, 10:17 PM
From Carling:
Code:
Good Afternoon,
The switches in the pictures were manufactured by our competitor McGill.
That rocker style is unique to them
Thanks, Ernie
Ernie Olson
Applications Engineer
It's all I got so far.
John 3:16-18
Old 11-30-2017, 08:51 AM
Mine is not the bulbs for sure.. They look fine.. I think I will just get my dealer to send me the one that lights up blue and run with it.. I'm never going to sell this boat anyway and just need them to work.
Old 11-30-2017, 11:40 AM
Looks are very problematic with light bulbs on boats, the pounding of waves and corrosion can easily cause the lights not to work - atleast unscrew the bow light assembly and use a voltmeter to test it - you will likely have juice there and if not you can set many voltmeters to "audible" and then start wiggling wires/fuses/connections and it will start chiming at you when you find the problem.
Old 11-30-2017, 02:17 PM
Good call.. I will make sure if have my meter next time I'm at the lake house..
Old 11-30-2017, 02:26 PM
you could always fly out TT mastermind to the "lake house" too
Old 12-04-2017, 01:47 PM
I think you would like it buddy!!!
