Old 01-08-2012, 10:12 AM
tmacx2's Avatar
tmacx2 tmacx2 is offline
X2 stock ballast
Does anyone know how much stock ballast the X2 (2011) has and the amount for each tank? I see conflicting numbers on this. I have read or been told anywhere from 650 lbs to 950 lbs. Nothing in the owners manual either. Thanks.
Old 01-10-2012, 07:07 PM
g-mantrix's Avatar
g-mantrix g-mantrix is offline
Boat: matrix sorrento 2006 315 mrcruiser
Thought I'd reply but don't quote me...200lbs in each rear tank and 350lbs in KGB (front). I have an 07 X2, I have added the 400lbs fly high in rear lockers all plumbed in plus just fitted the integrated bow sac, manual fill at the moment. I think the bow sac may add 500lbs and with 4 peeps in the boat the wake is solid with a sweet transition and a lip to boot. Real happy with this setup
Old 01-10-2012, 08:51 PM
tmacx2's Avatar
Thanks for the reply. I have read on this site before that the rear tanks were 200#. Wakemakers told me they were 250# and the dealer told me they were 300#. Just a little confusing. Sounds like you have a sweet setup. I'm happy with the wake for boarding but I'm going to try and improve it for surfing. I'm going to add the 455# rear sac for sure and probably a 370# tube sac on the surfside. I'm just trying to put an exact number to the amount of ballast.
Old 01-11-2012, 03:32 PM
davidstan's Avatar
davidstan davidstan is offline
Boat: 2008 X2
we have the stock ballast plus 450# in rear port side locker and ice chest filled with 175# of weights and just the driver and it is an ok surf wake. Wife free surfs it but not enough push for me so still have to hang on. i guess i just need more weight or bigger board.
David
2008 X2 MCX
1999 Maristar 210 (sold)
1996 Bayliner 2050
Old 01-11-2012, 03:39 PM
ttu's Avatar
ttu ttu is offline
i think the 200 lb in each rear is correct. i also have the fly high x2 rear ballast bags on top of the tanks. i added the surf sac last year when it's just a friend and i at the lake... wow
Old 01-11-2012, 09:18 PM
MattsCraft's Avatar
I can't believe know one has the answer to this... Prior to the increase total was 550#, 250# KGB and 150# in each rear, so the 200# number for the rears sounds correct but it could be 250#, I do not think the KGB has any more room to increase, but I have not looked at new ones to notice.
The 250# in each rear makes sense, this would give you 750# total weight. The X2 for wakeboarding anyway likes and does very well with a 60 rear to 40 front ratio.
My set up is stock, 425# filled to 75-80% capacity in the rears, KGB full and a 350# center if we are 5 or less people in the boat.
Old 01-12-2012, 05:35 PM
davidstan's Avatar
Boat: 2008 X2
Where did you install the surf sac, the L shape has me confused unless it sits on the rear seat area. Does anyone use the portable 150# little fat sacs?
David
2008 X2 MCX
1996 Bayliner 2050
Old 04-08-2012, 08:36 AM
Set Set is offline
Boat: 2005 Tournament Team Prostar 197,MCX/Powerslot Transmission,Mini Tower Sold
Smile
Originally Posted by sand2snow22 View Post
What year is your X-2? Newer X-2 have bigger tanks in the rear!
Did you just piggy back the fly high sacs and if so how did you deal with the 07 6 min timers ? I've plumbed in the rear sacs and will be doing the bow this spring but I haven't dealt with the timers yet, debating by passing or buying three timers but they seem to be $100.00 bucks each. Any input will be appreiated thanks.
Old 04-17-2012, 02:23 PM
tmacx2's Avatar
Talked to wakemakers today. They said the rear tanks are 250# and kgb 400# for sure. They said on 2003 and older they were 150# and 250# respectively. Said they keep info on all the makes and models and the guy I talked to told me he has a Mastercraft also.
Old 09-24-2017, 11:46 PM
LakeDays171 LakeDays171 is offline
Boat: Mastercraft X2 2008 MCX
Tmacx2 appears to have the final statement on the stock ballast total. Anywhere from the 750 total to the 900 total seems reasonable for that era to me. Just bought my '08 X2 this summer and would like to know best I can what it is "supposed" to be. I thought it was 750 and my buddy was saying it was over 1000.
Fyi, wakeboardingmag.com review quotes it at only 550#, seems too low me though.
http://www.wakeboardingmag.com/blog/...boats-x-2-2008
Thanks for letting me bring up an old thread.
