Old 07-11-2014, 10:19 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
I had the same problem. Did the same things. (new starter, charged & tested batteries, cleaned connections)
In the end, despite a perfect external appearance including the lugs, my engine ground cable had an intermittant internal fault causing high resistance.
I found the problem with my multimeter, used heavy duty jumper cables to test and upon replacement of the ground cable, never another issue.
Bailey
'02 X-9
Lake Blue Ridge
Old 07-11-2014, 10:23 AM
weist1013's Avatar
weist1013 weist1013 is offline
Boat: 2001 230
Send a message via Skype™ to weist1013
Thanks, I will check this tonight!! You guys are great.
www.reactorled.com
The After Dark Specialist
Old 07-11-2014, 11:32 AM
Good luck.
Peter
Tandem Axle Wheel & Tire Package $659
4 S5 or S5 Black 14x5.5 wheels, 4 ST205/75R14 Kenda Loadstar tires
Single Axle Wheel & Tire Package $399
2 S5 or S5 Black 14x5.5 wheels, 2 ST215/75R14 Kenda Loadstar tires
MOUNT, BALANCE & FREE SHIPPING INCLUDED IN BOTH PACKAGES
CARB REBUILDING - FAST TURN-AROUND - $100 +PARTS
LED lights, Hubs, Spare Tire Carriers, Chrome & Powder Coated Lug Nuts - Red, Blue & Black
PM or email me tiresplease@gmail.com
Old 07-11-2014, 11:37 AM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
Did a little work in High School at an auto electric shop. Seems like more than half the time people came in with a "bad" starter, it was just the ground strap between the engine block and chassis that was the culprit. . .a $5 fix back then. Often the simplest fixes are most overlooked.
Old 07-11-2014, 10:48 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
Even if the connections "look" good, go ahead and clean them anyway. It is worth it even if it doesn't cure your problem.
Click on the link above for Jabsco repair parts, including bearings, o-rings, lip seals and many other ballast pump parts.
Old 07-29-2014, 04:53 PM
weist1013's Avatar
Boat: 2001 230
Turns out it was one of my new batteries went bad, only 2 months old. Replaced it and starts great.
www.reactorled.com
