Old 09-14-2016, 07:26 PM
88 PS190 88 PS190 is offline
I've tried several other vacuum pump brands - the vertical one from mityvac is the best I've used other than real vacuum pumps like a gast coupled to a tank.
I recommend extending the hose if you need to.
Old 09-15-2016, 08:33 AM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
I used this one for the first time this year, and it works great. Not a single drop spilled.
https://www.amazon.com/BikeMaster-Oi...luid+extractor
Old 09-15-2016, 08:40 AM
Originally Posted by gt23 View Post
what i got back from Ilmor
When changing ATF to 15W40 oil this is what‘s required:
1-You have to suck all the transmission out by removing the dipstick and placing a suction tube inside the transmission.
2-You have to change the transmission filter.
3-Add 3 quarts +/- to fill.
4-15W40 Rotella is fine to use.
Nope, It's a metal mesh filter that can be completely cleaned.
Tim
Old 09-16-2016, 09:09 AM
jharmon203 jharmon203 is offline
Boat: 2000 X-star
It looks like metal mesh on the outside, but the inside looks like a pleated paper filter. Am I wrong?
Old 09-16-2016, 09:13 AM
Boat: 2000 X-star
Originally Posted by MeanV2 View Post
Anyone ever try one of these for emptying the transmission fluid out?http://www.ebay.com/itm/130894427851...%3AMEBIDX%3AIT
Or is a hand pump better? Thanks!!
Dan
Dan,
Do yourself a favor and never buy a drill pump. You will save yourself a ton of time by spending a bit more for one of the oil extractors that many people have posted on here. You never have to worry about priming or power with these type of pump oil extractors.
Personally, I didn't want to get an electric pump because I didn't want to have the requirement of having power to do my oil change. I use the topsider and it works great!
https://www.amazon.com/America-5060-...words=topsider
The other "vac" on here is a bit more expensive and I hear works great as well.
Old 09-16-2016, 09:41 AM
MeanV2 MeanV2 is offline
Boat: Searching
Thanks for all the Great advice and recommendations. I had a feeling this was the case.
Dan
you are wrong it is all metal inside and out.. and unless you had a catastrophic failure leave it alone. I took mine out there is no value add to doing it... unless you want to spend a couple more hours fricken around in your boat...
Old 09-16-2016, 11:39 AM
It's 100% metal. I had bought a new filter thinking I would need to change it when I changed the oil in the trans. As it turns out it's cleanable and reusable. I now have a spare sitting in the shop.
Tim
Old 09-16-2016, 12:14 PM
Boat: 2000 X-star
Ok thanks for clarifying that. Is it magnetic in there? That's about all I think that a metal filter could do as far as collecting debris.
Should it be cleaned at all with a change?
Old 09-16-2016, 12:34 PM
It is not magnetic. I believe the purpose is to trap debris down to a certain micron level.
I change my trans oil every other year and I do it through the filter port(I get a lot more fluid out over using the dip stick hole). While I have it out I rinse it in either gas or use brake cleaner and then blow it out with air.
Tim
