Old 05-23-2018, 06:07 PM
tbmlxstar tbmlxstar is offline
Boat: X-Star 2001
Ballast pump not working
I have a 2001 XStar with three ballast pumps. The two aft pumps stopped working. I looked at the impreller on one pump and it looks fine. I didn't check the other, hoping I could find the problem without getting into the other one.
When I flip the switch to fill or empty, the lights on the switch come on but no action from the pumps. Before I replace the pumps with new ones, is there anything I can check? Is there a fuse I can check and replace, and if so, where is it and how do I change it? I tried to remove the panel next to the driver's seat where the switches are but can't remove the bolts. They turn but do not loosen. Not sure what's up with that but it means I can't get behind the swithc to check if the wires are good.
Thanks for any help you can provide.
Old 05-23-2018, 06:14 PM
bcd bcd is offline
Boat: 2014 X-2
http://www.mastercraft.com/teamtalk/...ad.php?t=42810
Sent from my SM-G930V using Tapatalk
Old 05-23-2018, 06:16 PM
bcd bcd is offline
Boat: 2014 X-2
Are you getting voltage at the motors? That will verify the electrical switch and wiring.
Old 05-24-2018, 07:59 AM
Boat: X-Star 2001
Not sure about the voltage, I didn't have the right equipment with me but I will try that today. If no voltage, that means wiring or the switch is bad, right?
Thanks
Old 05-24-2018, 08:12 AM
There should be inline circuit breaks for each pump as well. Check to make sure they are not tripped.
Tim
