Old 03-27-2018, 08:42 AM
Pno02 Pno02 is offline
Boat: Mastercraft xstar 2005 350 mcx
2nd Gen X-Star piggy back ballast plumbing
I am installing lines from Wakemakers to fill fat sacs off of the factory tanks. I was able to install the port hoses without any issues. I looked at the starboard side and it looks like there is not much room at all and lots of wires to work around from the dash area. Does anyone have any suggestions for an "easier" way to run these hoses?
I was considering buying a small diameter pvc pipe and routing it where the hose will need to run and then sliding the hose over the pvc so that it would provide a path for the hose to follow. Does this sound like it might work?
Thanks in advance!
Old 05-10-2018, 07:45 AM
For anyone who runs into this issue in the future. I used a 3/8" od piece of metal tubing to assist with the install. The tube was approximately 4' long and I slid it into the wakemakers hose. I then taped the hose to the metal tubing and pushed it the entire length. It took less than 2 minutes to install the fill/drain and vent hoses.
