Old 05-26-2018, 07:21 PM
cdp082 cdp082 is offline
Boat: 2011 Mastercraft X-45
Pump filling but not draining.
My port side jabsco ballast pump is filling but not draining. I replaced the impeller which looked fine and that didnt help at all. The starboard side and kgb are louder when turned on/off and fill a littler quicker than the port. Could this just be that the pump needs replaced or something im overlooking? Boat is a 2011 x45.
Old 05-27-2018, 09:54 PM
Waterbucket1 Waterbucket1 is offline
Boat: 2015 X23
I'm having the same problem on the same side. Everything fills in about the same time. But the port side drains down to about 6" in the rear locker sac and will not pump out below that. I've tried it on the lift and still wont drain. This is in a 2015 X23 any advise on where to start. I have not changed the impeller or explored very far.
Thanks
Chuck
Old 05-30-2018, 10:18 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
First thing to do is get a multimeter and test if you have voltage at the quick disconnect plug next to the pump. You'll need some needle style probes. You should see at least 12 volts when you turn the pump switch to fill and then when it empties it should also be at least 12 volts but with the opposite polarity. If you have good voltage in both cases, your pump is the problem. Sometimes, the plug on the pump end can be flaky. I had one pump that quit working, I plugged it in and unplugged it a couple of times and it started working again.
We defy the mafia!
Old 07-11-2018, 04:01 PM
RedDawg RedDawg is offline
Boat: 31' Jupiter CC Twin 2008 300 Yamaha HPDI
My Jabsco waterpuppy pump was only working in one direction also. After some troubleshooting, I determined that my power source was dropping too much voltage - the running voltage had dipped down to 10 Volts (starting Volts drops even lower). The impellar is designed such that its impellar "blades" rub up tightly against (and bend) at the pump volute. It requires more torque (power) to reverse these blades and therefore it is crucial that you have proper voltage to the motor to accomplish this. My problem was excessive voltage drop at my power panel from my batteries. It also could be insufficient wire size from your pump motor to the connection point and switch. I hooked up a fully charged battery directly to my power panel and my pump ran fine in both directions. Static Voltage was 12.4 Volts and running Voltage 12.1 Volts, about what I expected. Running Volts is what counts so that's what you need to check. You can put a Voltmeter right across the motor connections at the panel to verify. Anything less than 11.5 Volts may not be enough to reverse the pump blades. Jabsco also says that their polyurethane impellers have the least resistance to reversal so that might help also. Their standard impellars now are Nitrile I believe.
