Old 05-20-2018, 10:19 AM
dleath dleath is offline
Boat: NXT 22
NXT 22 Ballast problems
I have the factory added plug and play installed. For some reason, the starboard side pump will not prime and engage, the center and port work great. My only way around it is to open the engine cover, remove the heavy black heat protectors, and manually twist the pump top to bleed it. After that, it works fine. is there another way to bleed the line besides getting burned by my engine? I wish it was as simple as just flipping the switch like it was marketed to me. I have taken it to my local dealer several times and they state it works, yet the problem still persists. Any advice is appreciated.
