  #6861
Old 03-19-2017, 03:27 PM
ryancassidy ryancassidy is offline
Boat: 2017 X10
No pictures yet.... but took delivery on my 2017 x10 on weds PM.
Installed new speaker LED rings and switch
Upgraded rear blast bags to the larger wakemakers.
Installed new dual battery charger
Replaced the M400 with a M800 amp.
Installed an OJ815 prop.
Still have the docking lights and the fender clips to install. More to come (and pictures )
Old 03-19-2017, 03:54 PM
Yooper Yooper is offline
Boat: 2014 ProStar
I turned the battery tender switch on.
Old 03-19-2017, 09:27 PM
81SNS 81SNS is offline
Boat: 09 X2
Installed my batteries, checked out the amp I installed last weekend, and changed all ballast pump impellers to the newer green impellers, I wanted to flip the pump motors but I don't think there was room where the motor would be sticking up from hitting the angle on the inner transom.
Old 03-19-2017, 09:42 PM
Olaff's Avatar
Olaff Olaff is offline
Boat: 2001 Prostar 205V. 1982 S&S Powerslot (sold).
I put some fresh 92 octane, put the hull plug in, and went for a ride all afternoon with the wife and kids. Nothing else needed!
Lake is 72 degrees, air 82 degrees.
Old 03-19-2017, 10:20 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Pulled off the cover, hooked it up to the Suburban, wiped it down, ran on the muffs then took a 45 mile cruise on Lake Austin.
Mike B
Old 03-20-2017, 04:12 PM
jmstu76 jmstu76 is offline
Boat: 1997 Prostar 205 Sammy Duvall
Re ran all new air guide speedo tubing. Hooked up the 12v power to the heater switch. Had all the metal vents powdercoated. Replaced both backing plates on the trailer, new soft lines and new hard line. New UPF A-60 master cylinder.
James
[email protected]
Old 03-20-2017, 04:43 PM
paintpollz's Avatar
paintpollz paintpollz is online now
Boat: 2002 Prostar 197
Sounds awesome. Hammer down!
Kevin
Old 03-22-2017, 03:38 AM
PNB MasterCraft PNB MasterCraft is offline
Boat: x10, 2015, Ilmor 5,7
- Did a clean up of the tower and put some wd 40 to all aluminum parts.
- Removed the bimini cover for a cleaning.
Nicolai
Old 03-23-2017, 06:26 PM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
Installed new tower speakers
Krypt 7.7 with new cans
Old 03-23-2017, 06:27 PM
New rack for the tower that will hold a kneeboard and a wake board
