Old 05-29-2017, 11:31 AM
chadsy chadsy is offline
Boat: 2010 mastercraft x2
2010 Mastercraft X2 - 5.7L Indmar Engine Overheating
I have an overheating issue with my X2.
At idle, everything is good. I have water circulation (I can see water movement in the strainer) and the temperature is 165 F. I take is out on the lake and increase the rpms and the strainer empties and the engine heats up (200 F). I've removed the raw water pump impeller and it looks good. Thinking the next steps are to replace the impeller and thermostat. Any other suggestions?
Old 05-29-2017, 11:54 AM
tex599 tex599 is offline
Boat: 1981 Mastercraft S&S, 2001 Prostar 209, 2018 Bu 21 MLX
I would start with replacing both the thermostat and impeller, even though it looks fine, it can still cause problems. I don't have strainer on my boat, so not sure if there can be an issue with that. But it sounds like your not able to pull enough water through pump, which would be the impeller.
Old 05-29-2017, 12:02 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Possible air leak in the strainer? Under higher rpms, might be suckin some air.
No point in looking for an answer here until you check the impeller. If that's good then I'd take the strainer out and run direct and see if that's the problem.
'06 X2 MCX
Old 06-28-2017, 07:01 AM
Thanks
Thanks for the replies.
Even though the impeller on the raw water pump looked fine, I replaced it. This has solved my problem!
Old 06-28-2017, 08:50 AM
wheeler's Avatar
wheeler wheeler is offline
Boat: 2007 X2
I had an impeller where the rubber separated from the brass center, so the impeller looked fine but the rubber fins were not spinning with the brass center. That is why it is good to change them every year, regardless.
2007 X2 - Current
2004 X10 -Sold
1997 ProStar 190 - Sold
1993 ProStar 190 Star & Stripes - Sold
Old 06-28-2017, 11:58 AM
Breiti's Avatar
Breiti Breiti is offline
Boat: MasterCraft X2 2010 Indmar MCX GEN2 LPG
Got the same issue at the same boat last year,
forgot to reinstall the seal on the bolt of strainer and it sucks air at higher rpm.
impeller, indmar, overheating, thermostat
