Old 06-05-2013, 04:05 PM
Brian B's Avatar
Brian B Brian B is offline
Boat: Brand new 01 X10
First prop strike and vibration
While at lake Powell for Memorial Day I have a little run in with this sob!
We were just idling in at night and the engine shut down the second the prop hit. If you look at the prop you can barely see that it is damaged. Like not at all. But it did vibrate so I threw a spare on the next morning. I now have a slight vibration at speeds over 30 mph so I would assume I have a bent prop shaft.... ( I could very well have a slightly damaged spare prop I suppose )
Do the shafts typically bend at or near the prop?
What would be acceptable runout?
Degree of difficulty to change it?
Thanks for any input!
Old 06-05-2013, 04:18 PM
Brian B's Avatar
Damaged prop
Old 06-05-2013, 04:22 PM
I would check the prob - you can also use a needle gauge to see if shaft is bent. look at post #28
http://www.mastercraft.com/teamtalk/...t+guage&page=3
Old 06-05-2013, 04:24 PM
rtw_travel rtw_travel is offline
Boat: 2014 X-14V
It's a rogue rock! Been there, done that on a previous boat.
What is the history of the spare? Most people's spares are previously damaged props.
2014 X-14V
2012 X-14V (gone)
Old 06-05-2013, 04:31 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
brian, that damaged prop is definitely out of square
Old 06-05-2013, 04:35 PM
aquaman's Avatar
aquaman aquaman is offline
Boat: 93 Barefoot 200 Yamaha 225F
agreed, major distortion in the blades.
with that kind of damage i would supsect a bent shaft before blaming the spare prop.
Brian B's Avatar
It was the spare that the previous owner had so you may be right..... My local dealer is lending me a prop this week to try!
Old 06-05-2013, 04:36 PM
Brian B's Avatar
The angle of the photo certainly helps it look out of square....
Old 06-05-2013, 04:56 PM
cruiser cruiser is offline
Use a dial indicator. Make sure your strut bearing is good, (don't want any shaft play.) Turn the shaft and watch the indicator. .000/.003 is within tolerance. any more you will need it straightned by a machine shop with capabilities.
Old 06-05-2013, 05:12 PM
Brian B's Avatar
Thanks! How hard is it to pull out?
