Old 06-15-2013, 10:55 PM
Bluccous's Avatar
Bluccous Bluccous is offline
Boat: 1985 stars and stripes
Ballast resistor
How is the ballast resistor wired on a 351 Windsor?
Old 06-15-2013, 11:12 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Purple wire from ignition (same purple that goes to choke) on one terminal and usually an orange or purple wire from other side terminal to positive side of coil.
/spôrk/
Old 06-16-2013, 01:55 AM
Bluccous's Avatar
I have a red wire and a purple under one terminal. The purple was going to the coil and the red was going to the choke. The other side of the resistor has nothing on it and I believe that's why my coil is burning up so often. Where should the other wire go on the resistor? To the alternator? Or the starter selinoid? Thanks for the reply by the way!
Old 06-16-2013, 07:59 AM
The resistor isn't for the coil, it's for the points. They don't live long with 12V on them, so they put the resistor on it to decrease the current.
Old 06-16-2013, 09:25 AM
Spork's Avatar
Boat: Sporkcraft
Get your dvom out and see what voltage you have on the red/ purple wires.
In your case the RED wire same as choke goes on one side terminal but you need some sort of 12v input to resistor, and the Purple wire on the other terminal that goes to the positive coil.
I assume you have a PCM
PCM diagram (similar but you get the idea)
Old 06-16-2013, 10:21 AM
Bluccous's Avatar
Thank u very much for the help . Very good info. Thanks !
Old 06-16-2013, 10:33 AM
Bluccous's Avatar
One this diagram what is the jumper wire for on the resister it says for El , and do I need that green wire from resister to alternator also? It currently doesn't have one.
Old 06-16-2013, 10:44 AM
Doesn't have a wire, or doesn't have a green wire? The color doesn't matter as much as whether it has a wire. If you see a red wire (or orange) AND a purple wire, the purple wire does what the green wire does, except that it goes through the ignition key.
Old 06-16-2013, 10:53 AM
Table Rocker's Avatar
The EI jumper is used when you have an internally resisted coil. I believe the internally resisted coils are 3 ohm and the coils that use a ballast resistor are 1.5 ohm. You don't want to run a 1.5 ohm coil very long without a ballast resistor. Sometimes there is a bypass for full voltage when the starter is engaged, but that would be it.
j.mccreight had another nice post on the subject here:
http://www.mastercraft.com/teamtalk/...9&postcount=14
'96 ProStar 205 SD LT-1
Old 06-16-2013, 04:19 PM
ahhudgins's Avatar
The EI means Electronic Ignition. Most (not all) after market EI kits have you jumper out the ballast resister in order to run full battery voltage.
351 windsor, ballast, resistor coil
