Old 05-23-2018, 12:26 PM
197 TT's Avatar
197 TT 197 TT is offline
Boat: 2016 X2 and 1985 SS (Sold - 2008 X2, 2003 197 TT, 1993 205)
Originally Posted by MLA View Post
Am i just overlooking? How many speakers are there? Other then 2 woofers, I dont see how many
Bow?
cabin?
Tower?
Two subs, 6 cabin, two towers...
2016 X2 - Current
1985 SS - Current
2008 X2 - Sold
2003 197 TT - Sold
1993 205 - Sold
Old 05-23-2018, 12:42 PM
MLA MLA is offline
Boat: pontoon
#1 700/5
woofer zone (RCA split)
4 main cabin each on their own chnl RCA does not require splitting
#2 700/5
Front L&R bow pair zone RCA not split
Rear L&R tower pair zone RCA not split
10 amp chnls and 10 speakers. Only RCA zone to split is the woofer. System plays in stereo.
If speakers dont play music, change the input switch. if the speaker play but are controlled by the wrong zone, change the in-put switch.
Old 05-23-2018, 03:19 PM
TarheelMC TarheelMC is offline
Boat: 2017 X23
#1 700/5
#2 700/5
How do you figure that you don't need to split the RCA for the 4 speakers on the same zone? Per the M700/5 manual, if in 2 channel mode, channels 3+4 & the sub channel get their signal from 1+2. If in 4 channel mode, you supply signal to channels 1-4 & the sub channel is a sum of channels 1-4. If in 6 channel mode, the sub can be controlled independently and is not a sum of any channels.
Did I overlook something in the manual? Also when I say split RCAs, I'm saying the zone for the 4 speakers will need Y-adapters and plugged into zones 1-4.
Old 05-23-2018, 04:47 PM
MLA MLA is offline
Boat: pontoon
With a 4 chnl and 4 speakers that will all be under the same zone, only a single pair of RCA (1 left 1 right) to drive all 4 amp chnls.
I may be mistaken of the 700/5, but I was under the thinking that 1-4 can be driven by a single pair when in 2 chnl mode and the woofer can be driven independent with its own RCA.
Worst case, you are splitting right at the amp's input, rather then having to split the RCA further upstream because the speakers are on separate amps.
Old 05-23-2018, 09:20 PM
Boat: 2017 X23
Im pretty sure hes going to split the signal. I looked at the JL manual again, and to use the subwoofer channel with zone control, the amp will have to operate in 6-channel mode. Otherwise the amp combines channels to supply the subwoofer signal.
http://mediacdn.jlaudio.com/media/mf...pdf?1453415373
Old 05-23-2018, 09:42 PM
MLA MLA is offline
Boat: pontoon
Still the best way to configure it. Only zone split between the 2 amps, is the woofer. Only splitting the cabin zone right at the amp in order to occupy the 4 inputs on one amp, is nothing.
Old 05-27-2018, 09:21 AM
197 TT's Avatar
Thanks for the help, everything works correctly now, and I did have to split the bows... sounds great
2016 X2 - Current
1985 SS - Current
2008 X2 - Sold
2003 197 TT - Sold
1993 205 - Sold
