  #531
Old 05-26-2018, 07:22 AM
trunderw trunderw is offline
Boat: 2008 X-14 MCX w/Powerslot
I hang them from the tower, or tie one to the cleat on the dock.
boats rock, but don't rock the boat
Old 05-26-2018, 08:22 AM
rtw_travel's Avatar
rtw_travel rtw_travel is offline
Boat: 2014 X-14V
Oooops
2014 X-14V
2012 X-14V (gone)
Old 05-26-2018, 08:24 AM
rtw_travel's Avatar
Boat: 2014 X-14V
Originally Posted by Krw1225 View Post
Question for fellow x-14/214 owners, when docking at the marina/dock, or wherever you are that requires you to put the bumpers out. Do you find that you have to have them basically touching the cleats? The distance between the cleats/rub rail/gunwales leaves no room for rope before it drops the bumper below the rail? I find that this hull sits so low in the water that the docks are usually above the boat. Hope my descriptions are making sense for my question. Just seems very odd and donít feel like itís right. Thanks for input in advance.
Also could just be that the marina Iím at just has high floating docks
I did two things:
I bought larger fenders, and
I installed phender pro. https://www.mastercraft.com/teamtalk...ad.php?t=57411
Itís still a bit of a problem on the rear fender. The rope is very short ( just over the rub rail) and the bottom of the fender floats on the water so it does not hang straight down ... but it does fend off the dock properly.
2014 X-14V
2012 X-14V (gone)
Old 05-26-2018, 09:29 AM
Krw1225 Krw1225 is offline
Boat: 2008 X-14, 40th Anniversary Edition, MCX w/ Powerslot
Thanks - all good ideas and reassuring that I’m not crazy. Using the tower is an interesting thought, because the way the hull curves in at the bow, the middle of the boat could still touch.
Id love to see a pic of the set up to hang them off the tower.
I’ve also though about the phender Pro because when you use the boat cleats for the bumpers/fenders it doesn’t really leave room for the tie down lines.
The summer of learning, got to love it!
Old 05-26-2018, 09:39 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
I should have given you my fenders. I used the angled ski boat fenders. I tied one to the front grab rail with a hitch knot. In the middle I had one with a loop tied into it that I would hook to the tower knob, and in the back I tied another one with a hitch to the rear grab rail. I had to use the grab rails because, as you said, the cleats are so low.
Old 05-26-2018, 10:35 AM
rtw_travel's Avatar
Boat: 2014 X-14V
The best pic I have is near the bottom of the phender pro thread that I linked to above.
That was my old old and a smaller fender than what I use now.
Rather than tie it to the tower, I have loop in the fender line about 10Ē above the fender, and clip onto the loop with a gated stainless hook that is tied on the free end of the line. I.e. tie a hook to the end of the fender line, wrap it around the tower base and hook it onto the loop. No knots to tie and no guessing about the right height. That is mostly visible in the picture
2014 X-14V
2012 X-14V (gone)
Old 05-26-2018, 10:24 PM
davidrezin davidrezin is offline
Boat: 2010 X14V with LY6
Hello All...
Any Wake Surfers out there? I'm aware the Mission Delta Wake Shaper potentially fits an X14V however I was curious if there are any X14V Enthusiasts out there that have used any other makes/models witj succes? The X14V has some unique contours at the rear and bottom of the boat which lends itself difficult to finding a Wake Shaper that fits.
Thanks in advance!
Old 05-27-2018, 09:41 AM
Rhob88 Rhob88 is offline
Boat: 1994 mastercraft 205
I got a swell wake surf model , and it works great , and it floats and it’s easy on the wallet
Old 05-27-2018, 10:37 AM
if they donít work on the new boat, maybe we can work something out!
Old 05-27-2018, 10:38 AM
Thanks for link and ideas!
