  #41
Old 07-18-2014, 07:49 PM
vipermeat vipermeat is offline
Boat: 1979 Stars and Stripes
We got the lift/cradle on the dock and it works..... small victories. I am concerned about the angle bow to stern. I pulled the drain plug and no water came out. There is water under the engine but not enough to get sucked out by the bilge. Is that normal, or should I modify the lift so the boat sits at an angle?
Next question: should water be getting to the area where the exhaust hoses are? If so, how does that water drain? If not, I have some investigating to do. Thanks again.
Old 07-20-2014, 10:39 PM
Olaff's Avatar
Olaff Olaff is offline
Boat: 2001 Prostar 205V. 1982 S&S Powerslot (sold).
Pre-83 Bilge Pump Issues
Viper,
That red thing was in the boat from the previous owner and he politely removed it before I took ownership of the vessel.
As far as bilge water and where it drains etc.; me and another newbie (81mastercraft) were discussing that very thing. The stock location of the bilge pump is right above the second (middle) tracking fin, which is below the forward half for the engine oil pan. From my observations of sitting dead in the water, underway at various speeds, or sitting flat on the trailer, that location is "high ground" in the bilge as far as I can tell. I have flipped the pump switch to "manual" after a full day on the lake with kids in and out of the water and gotten nothing out. Immediately after pulling it on to the trailer and hauling it out of the water, but while still on the ramp incline, I pulled the transom plug and got about 2 gallons of water out. Then after the short 5 minute drive to the house, I blocked the trailer wheels while on my sloped driveway (facing up hill), got the kids to sit on the swim platform for counterweight, and lifted the tongue of the trailer until the rudder touched the driveway. Got about another 2 gallons out.
So this weekend I pulled up the forward floor panel to get access to the mounting hardware for my pylon so I could tighten up some wiggle in the pylon. What I found was about two gallons of water sitting in the deepest part of the "v" of the bow just below where the windshield is. This is while sitting flat on the trailer. I have seen pics of this era boat with an access port cut into the floor forward of the pylon, so I'm assuming either the factory started installing them up there, or owners found the flaw and moved the pumps themselves then cut the access port to be able to clean out the pump strainer.
So I considered moving the bilge pump up there, or running two bilge pumps but have decided against both. What I am going to do instead is essentially fill the low spot in the forward bilge/bow area that is inaccessible when the floor is installed so the water will naturally drain aft even at a level angle. I may be doing that this week and will post pics and a description of the project.
I'm going to start a thread describing what I did to reinforce the pylon. I'm pretty proud of my engineering on this one.... Then I will continue the thread with the forward bilge work.
Old 07-21-2014, 08:45 AM
Thanks Olaff. I removed most of the water with a hand pump before putting her to bed. I am going to raise the front of my lift to allow it to drain. I do not see any harm in it and no news on TT equals good news I hope. This should be temporary as I will take her off the lake this fall and get to work. What an awesome boat! With the age of all the seals and hoses I will baby her a little thus summer.
1979. trailer, cloaked
