Old 06-04-2018, 01:30 PM
TCUMasterCraft TCUMasterCraft is online now
Boat: 2003 MasterCraft X30
Board Racks for 2003 X30
Just bought an '03 X30 without racks. I know most of the original racks are long gone for this year but looking for ideas to get some boards off the floor. I did a custom Bimini that goes over the tower so that somewhat limits what I can do.
Any ideas as to what this is?
https://mcpartsdepot.com/products/bo...ounting-03-all
Old 06-04-2018, 11:17 PM
gweaver gweaver is online now
While my 03 came with wakeboard racks on both sides, I replaced one set with 'bat' surfboard racks from Krypt. LINK
All I actually used were the fingers- I removed them from the Krypt mount and used two metric bolts with lock washers to mount them to the mount plates on the tower. As I recall, I had to clearance the hole in the tower mount plate to get the correct size metric bolt to fit, but it wasn't by much. I think I used a step bit to do it. The other thing I had to do was undo the hog rings from the Krypt bungee, which mounts on their mount plate. I ran the bungee through two holes on the tower mount plate and re-clamped the hog rings.
Krypt rack:
How it's mounted:
Factory rack mount:
The wakesurf rack was $150, I think they have wakeboard racks for about the same, maybe a little more. I'd imagine you could get both sides done for 300-350, depending on which racks you choose.
One note- I think the racks are made in China- not an issue, other than the rubber pads have some kind of funky chemical smell to them, but that disappeared about a week after they were mounted. I've had them on the boat for a year, and I'm pretty darn happy with them.
edit- the Krypt racks come with a tower mount clamp, but I wanted a more 'stock' look- that's why I removed the fingers and mounted to the tower plate.
G
Old 06-05-2018, 12:30 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I put some 2004 racks on mine a few years ago. Had to cut a rectangle out for the handle and drill a hole for the screw above. The other two holes lined up. It was a pretty big pain to cut through the aluminum. I did it over the winter and took the top half of the tower off to make it easier to work on.
Old 06-05-2018, 06:43 PM
Awesome, thank you for the ideas. On the Krypt rack, when you go over your boards, what do you secure the bottom of your bungee to?
Old 06-05-2018, 07:55 PM
I loop the bungee to the rearward tower knob.
On a related note- the bungee on the stock wakeboard racks is very short- won't wrap all the way around a board, and I have no clue what it's supposed to hook to. One of these days I'll get around to replacing the bungee with a longer one that I can actually use.
G
Old 06-06-2018, 08:14 AM
pmkkdx's Avatar
pmkkdx pmkkdx is offline
Boat: Mastercraft, X2, 2004, Violet (purple) & white ... previous 1983 black/silver stars
where did you find the '04 racks? I have an '04 but only one side has a rack ... been looking for another but everything I find is stupid expensive.
Old 06-06-2018, 12:02 PM
JRW160's Avatar
Boat: 2003 X2
I found the set on ebay. Sold my 2003 racks and basically broke even.
There's a set on ebay now. It looks like they are $225 each, so $450 per side.
Old 06-06-2018, 12:51 PM
Wakerider16 Wakerider16 is offline
Boat: 2001 Prostar 205V
Prefer the http://www.diywake.com/ racks vs the non swivel stocks. What I have on my 205V
