Old 07-08-2007, 01:17 PM
rpliska rpliska is offline
Boat: 2001 Prostar 209
Broken Rear Seat - PS209
The rear seat in my 2001 ProStar 209 just snapped. I pulled back the upholstery and found that the base of the seat is this aluminum honeycomb stuff and is has broken. What should I do? Should I try to find the same stuff and replace it?
I called MasterCraft to get an entire new back seat and was told that they no longer stock them. Does anyone know where I can get a new seat?
Old 07-08-2007, 04:27 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
You can probably source a piece of the aluminum homeycomb stuff locally. Or you can buy a piece of HDPE (Plastic) and use that. Another less expensive alternative would be to remove the old and use a new piece of marine grade plywood as the base. Then staple back the old vinyl. Make sure you use stainless staples.
Old 05-28-2018, 08:01 AM
nortwr99 nortwr99 is offline
Boat: 2001 Mastercraft Prostar 190 EVO
Where would one find the honeycomb aluminum panels locally? Who should I be calling? Any help would be apprecaited. I have a 2001 prostar with a broken back seat. I would prefer to repair to stock with the light weight honeycomb if I don't have to order a $500 sheet online.
Old 07-02-2018, 10:57 AM
Creeklife's Avatar
Creeklife Creeklife is offline
Boat: 03 MasterCraft X9 MCX, 1991 MasterCraft Prostar 190 351HO
rpliska, did you ever find a solution for the backseat in your 209? Mine looks like it's been redone and is too short to fit across the top now as a sundeck. Looking to find a replacement or a rebuild
2003 X9
350 MCX
Zero Flex Tower
