Old 07-15-2018, 12:04 PM
ldelosreyes12 ldelosreyes12 is offline
Boat: 2005 X10 - MCX 5.7L
Fuel pump pressure regulator
Anyone know how to remove this? Can it be done from the top without taking the whole module out?
Old 07-15-2018, 01:18 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
There is a hose below that you need to disconnect. I'd take the whole thing out so you can easily work on it.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 07-15-2018, 01:26 PM
Darn. I was hoping not to have to remove the whole thing. I replaced the pumps and was putting it all back together when I noticed a leak spraying out of the regulator.
Thanks!
Old 07-15-2018, 02:16 PM
tr6coug's Avatar
Yup, I just went through the same thing. What regulator did you buy as a replacement?
Old 07-15-2018, 02:52 PM
Fuel pressure regulator
I am looking at this one from MCPARTSDEPOT :
https://mcpartsdepot.com/products/fi...iant=671317365
Going to call my local Mastercraft dealer tomorrow to verify and see if they have in stock.
I saw a pdf from Mastercraft online that said it was held on by a snap ring and could be serviced from above.
Again, I appreciate your help!
Old 07-15-2018, 11:56 PM
Fullpass's Avatar
Fullpass Fullpass is offline
Leaking Where?
Thanks!
Is the leak coming from the regulator fuel line connection on top of the regulator. I can't tell from the the pic for sure, did they cut the positive lock of the fuel line that connects to the pressure regulator? That line is under pressure and needs a positive lock connection, or maybe the internal O ring is damaged on the line. Just makes me wonder where a regulator could be leaking...pressure line going in...pressure line going out. Conection under neath or on top...Hole in the regulator body. Would like to know where its leaking, to look at mine>>>G
Old 07-16-2018, 08:44 AM
It started leaking around the base of the metal nozzle that the fuel line connects to. Not a very strong weld connection there.
Old 07-19-2018, 10:41 AM
Boat: 86 Magnum Skier
Mastercraft doesn't sell parts to these assemblies. You can buy it from your local parts store. Its a regulator for a dodge truck. Part numbers in the drop box and the fuel pump threads. It just pushes into the module assembly and the rubber grommet holds it in place. Would generally recommend using crimp clamps when replacing as many have had leak issues with screw type hose clamps.
Old 07-19-2018, 10:08 PM
My local Mastercraft dealer had it ordered in from Mastercraft. $35 part. You are correct, just had to pull it out and push the new one back in. Everything is working great.
Thanks for your input.
