Old 04-14-2016, 06:31 AM
whiskeyriver's Avatar
whiskeyriver whiskeyriver is offline
Boat: 99 prostar 205 LTR
Lead was used in gasoline to lower combustion temperatures. Hardened valve seats were implemented in engines to withstand the higher combustion temps of unleaded gasoline. Using unleaded gas in a "pre-unleaded" engine can cause valve and valve seat damage. Personally, I would pull the heads and have a machine shop install hardened valve seats and new valves. Shouldn't be more than a few hundred bucks. Until then I would definitely use a lead substitute/additive in the gas.
If you feel this damage has already occurred in your engine, an easy test is to remove the valve covers and rocker arms and lay a straight edge across the tops of the valve stems. Any deviation in valve stem height is a sign of trouble.
351, cam, engine, idle, shake
