Old 06-25-2015, 08:30 AM
Bubbacuse77's Avatar
Bubbacuse77 Bubbacuse77 is offline
Boat: Mastercraft Prostar 197, 2002
So I changed the oil and it looked like what was in there was thinner than 15w40. I also changed the plugs and there was some platinum plugs in it. I replaced them with the standard 43LTS and it started running better instantly. I noticed when I pulled the old plugs the back ones on each side had a lot of gas on them???
As for the oil pressure, I could not get it to have the issue again, even before I changed the oil. I suspect it was a bad/loose connection on the sensor above the filter. Now the oil pressure is 20psi idle when cold and 10-12psi when warm. Is this consistent with other 5.7 Indmars on here?
Old 06-25-2015, 09:43 AM
Rossterman's Avatar
Boat: 2001 prostar 205V
Guage in dash isnt very accurate so wouldn't go by that as gospel as could be off 5 psi high or low. If alarm isnt sounding you will be fine as it goes off if pressure drops under 4psi.
alarm, engine, horn, oil, warning
