Old 07-23-2015, 09:30 AM
Janks19 Janks19 is offline
Boat: 1977 mastercraft
Engine seems to be missing on accel
Alright team I am new here, I need some advice. I recently refurbished a 1977 Stars and Stripes and after about a month of running good the engine seems to miss a few cyclinders when I accelerate above 1000 rpm or so. The timing is good as is the dwell. During the rebuild I took the heads off to get reworked and had the carb rebuilt. Any ideas as to why I am having this issue would the appreciated.
Mike
Old 07-23-2015, 11:55 AM
Welcome to Team Talk. Always great to see another '77 around here.
Starting with the basics, Dist cap & rotor, plugs, wires all need to be serviceable. Great to hear you use a dwell meter to set your points. I would double check dwell and timing.
Check you coil voltage with key on/ engine off and with engine running. Should be seeing battery voltage, less ballast resistor.
Most likely causes of misfiring under load are bad cap & rotor allowing arcing to ground or bad plug or coil wire(s).
Old 07-23-2015, 12:54 PM
Thank you I will give those ideas a shot
Old 07-23-2015, 03:14 PM
gr82bgreen's Avatar
gr82bgreen gr82bgreen is offline
Boat: 1989 Prostar 190
Could be coil as well. Not a bad idea to change a 38 year old coil.
Old 07-23-2015, 03:31 PM
Oh yeah. No one ever regretted the money spent on that.
engine, miss fire, trouble
