  #91
Old 06-11-2018, 10:38 AM
Greenwood87 Greenwood87 is offline
Boat: 1989 Mastercraft Tri Star 190 - Sold
I also just sold this boat. In the market for a new one
Old 06-26-2018, 11:32 AM
TriStar190NTN TriStar190NTN is offline
Boat: Mastercraft, TriStar 190, 1989, Indmar 351
Your post has been extremely helpful to me in my rebuild; the pictures were outstanding. I replaced the center section of the floor, which had gotten soft. Basically what happens is that the wood gets wet and rots and the screws that hold that part of the floor to the walk-thru console eventually lose their grip which lets the floor sag. Your pictures convinced me that the floor piece could be removed without taking out the walk thru console: I used 2 tie down straps, wrapped them around the ski pull pole, put a piece of wood along the front of the floor board to keep the straps from damaging the lip on the board and ran the straps around the piece, then winched the floor pieced out from under the center console. I unscrewed the gas tank and slid it back towards the engine to get the clearance needed to allow the floor piece to pass over the gas tank fittings. If you do this repair, be sure to enlarge the hole under the passenger side of the dash where the gas tank clip screws are located so that it is easier to reinstall the screws afterwards, as removing these screws was difficult; I had to use a small Phillips head screwdriver that fit in my palm as that was all the clearance I had to work with. I replaced the screws with socket head screws and enlarged the access hole, but it was still a difficult installation. I was able to replace the wood and keep the original carpet, so that the new piece matches the rest of the boat. Thanks again for all the great suggestions from getting new dash plates from Greg Weaver (great guy by the way) to replacing the toggle switches and rehabbing the speedos.
Old 07-26-2018, 10:01 AM
Im really glad I could help! That's what this forum is for! Even though Ive sold my Tristar ( Looking at getting a newer Mastercaft), I can still answer questions about the Tristar repair, parts, ect.
Old 10-02-2018, 12:42 AM
Hawgdriver's Avatar
Hawgdriver Hawgdriver is online now
Boat: '06 X2, GSA, Plug & Play Ballast
Do you have any photos of your work?
2006 X2: GSA, 820s in the rears, 600 X2 horseshoe in the bow, Rub Rail Docking Lights
Old 10-02-2018, 07:51 PM
Hawgdriver's Avatar
Greenwood87,
How much does your drive shaft packing drip?
Mine drips about 1 drop or so a second I think but will verify.
Thank you!
Old 10-10-2018, 12:35 AM
Hawgdriver's Avatar
Can anyone please confirm where the vent hose runs on both sides of the tristar?
I know the blower hose goes to the starboard side rear vent but I don’t know where the hose goes from the starboard side, fwd or the 2, vents in the rear or where either vents run on the port side???
Lastly, where do all the vent hoses run from the heater core under the driver’s helm route to?
Mine is a mess!!!
