  #171
Old 11-06-2015, 12:38 PM
Emartski10 Emartski10 is offline
Boat: Mastercraft Prostar 190 Stars & Stripes LT1 93'
you guys that have used the Heavy-Duty Heat Reflecting from McMaster-Carr, have you notice the engine box trapping more heat? I have the LT1 in my 93' and it already has some vapor lock issues. The last thing I want to do is turn my engine box into an oven. Also worried about having enough space with 1''.
Old 11-06-2015, 12:41 PM
Rockman's Avatar
Rockman Rockman is offline
I have not noticed any over heating or excessive engine heat.
Just make sure the area around the cup holders is cut of correctly to get a little bit of air in there...also make sure your vents and tubing from the windshield are not blocked so you can get air in that way as well.
Old 06-12-2016, 09:39 AM
Skier Steve Skier Steve is offline
Boat: Mastercraft 197, 2002
Smile
The old stuff just crumbled as I took it out. Thought I would use it as a pattern, but no go....
Best to make a paper pattern first and then cut out pieces of insulation from flat stock? Or is there a better way?
Anybody make PRE CUT insulation pieces that you can just glue in?
My boat is about 2 hours away, and I don't have measurements. If I want to order flat sheets of insulation and cut it out myself, how much do I need? I'm hoping that someone who has done this before remembers!
Thanks so much.
Old 06-12-2016, 10:37 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Check my earlier post #20 in this thread. My install was for a TriStar but the overall quantity of material needed should be similar.
2005 X2, Viper Red, MCX, OJ TZ-X5 prop, PPass, rear 750 sacs, KGB, IBS, Bennett Wake Plate, custom wake shaper
Old 06-12-2016, 05:38 PM
So, you ordered 8 linear feet of the 54" wide material?
Did you get the aluminum faced material with the adhesive on the back?
Is the adhesive OK at typical motor box temperatures?
Thanks!
Old 06-12-2016, 10:12 PM
wheelerd's Avatar
Boat: 2005 X2
Don't remember the exact width. 54" sounds about right. No, I didn't use the aluminum faced stuff -- didn't like the looks of it. I think the plain gray stuff had a higher absorption cooeficient anyway. Adhesive was fine in the 2 years I owned the boat after doing it. I just made sure I cleaned off the old stuff really well.
