  #111
Old 02-18-2014, 06:43 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
Originally Posted by MI_Corey View Post
Ran a batch today of around 25 pcs. PM me if you want some. $6 each and $3 shipping.
Good things come to those who wait. Those look nice, and that was fast!
As a side note - NCS made a change to the depth from the original drawing on the ones he made. He measured his panel and decided the new custom grommet/washer would have bottomed out on the fiberglass without holding the panel tight.
He asked for the measurement on mine as well and decided a shallower depth would work better to ensure a good hold. Evidently not all models armrest panels are made to the same depth. ??
Jeff
Old 02-18-2014, 06:46 PM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
The depth on the drawing he gave me was .75 from the backside of the shoulder. If I need to make some shallower ones let me know.
Old 02-18-2014, 10:03 PM
rydog rydog is offline
Boat: 2002 X-Star, 2008 X45 LY6
Anyone have any idea what depth is needed for a 2002 xstar, or has anyone used these for that boat? I want to get some and I am assuming these should be the correct size? Boats in storage so I can't check easily.
Old 02-19-2014, 11:55 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I used them on my 2003 x-2 which has the same panels. They fit perfectly. Have fun getting the nut on the back of that center screw. It took me several frustrating hours.
Old 02-19-2014, 01:03 PM
I never looked at the panel closely this summer so I guess I have a lot of fun in store for me this spring when I replace the broken ones. Also how many did you need to replace yours, 3 or 4?
Old 02-19-2014, 01:17 PM
JRW160's Avatar
Boat: 2003 X2
Only 3. The two outside ones aren't that bad. To get the center one back on, I had the nut taped to the end of an open ended wrench which was held by a set of vise grips, which was held by a 5'7" 85lb 13 year old girl.
To get the panel off, there are the 3 screws at the top with nuts on the backside of the fiberglass. Then there is a single screw in the center near the bottom. There is a hidden one on the panel towards the rear of the boat about halfway up. You can't see it from the front of the panel, but there is a nut holding it on from the backside. I removed the throttle arm and ring, but I didn't have to take out the throttle assembly.
Old 02-19-2014, 01:19 PM
Only 3. The two outside ones aren't that bad. To get the center one, I had the nut taped to the end of an open ended wrench which was held by a set of vise grips, which was held by a 5'7" 85lb 13 year old girl.
Perfect
Old 02-19-2014, 02:09 PM
MI_Corey's Avatar
Boat: 2008 X1
If anyone wants these and they end up being too long I will make you shorter ones and send them out. I would just need to know how much shorter.
Old 02-26-2014, 10:28 PM
VP46's Avatar
VP46 VP46 is offline
I sent you a PM on this very subject - the grommets are fantastic but 2 of the 3 are too long/deep. I'll measure and post pics of what I am talking about shortly.
Old 02-27-2014, 01:44 AM
CrazyJohnny's Avatar
CrazyJohnny CrazyJohnny is offline
Boat: Mastercraft, X10, 2006,5.7
Pmed you Corey, I'll be in for these once VP46 gets the measurements dialed in!
