Old 07-10-2018, 12:53 PM
jsturvey's Avatar
jsturvey jsturvey is offline
Boat: 1998 MariStar 225VRS
Originally Posted by skymonkey View Post
Awesome!!! Thanks man
Sure thing!
I'll also include my improvement thread as well.
http://www.mastercraft.com/teamtalk/...ad.php?t=60004
Joe
1998 MariStar 225VRS, 350ci LT1
Authorized Dealer for
Old 07-10-2018, 01:22 PM
skymonkey skymonkey is offline
Boat: 2000 MariStar 210 VRS EFI
Originally Posted by jsturvey View Post
Sure thing!
She’s a great looking boat. Looks just like mine. I was going to ask where you got your decals? They look great but then I saw where you removed them. I know a lot of folks remove them permanently, but we love the true retro look. Plus I can’t get rid of my shadows. We’ve even wet-sanded them but the fading was so bad on the port side from years of neglect. I think putting replacements over will look better. So are you still running 15-40 in your V-drive? Mine has that “rock tumbling” sound at idle too.
Old 07-10-2018, 01:48 PM
jsturvey's Avatar
The decals were original to the boat. I'm like yourself, and strive to keep originality, but it was time for them to go. The starboard side decal had several holes and rips in them from dock rash by the previous owner, and the color was starting to come off all around. Plus it was next to impossible to polish any oxidation around them without damaging them more. I keep going back and forth about replacing them, but I'll leave it clean for now. Keep working yours with some 3M Restorer wax (or something the like) and a buffer. The shadows will come out eventually.
As far as the transmission goes, since your's was left neglected and unused for so many years, it would be a very wise idea to change the fluid. The Rotella 10W40 is an excellent option that I would recommend. It made mine run noticeably quieter. Now that I think about it, you should probably check and make sure the transmission cooler didn't internally fail from the freeze damage. Check the fluid for water intrusion.
Joe
Old 07-10-2018, 01:54 PM
So far I haven’t seen any water intrusion into the ATF. So conventional 10W-40? Do you pump the fluid out of the fill port?
Old 07-10-2018, 01:57 PM
jsturvey's Avatar
That good! The only port I ever found on the transmission is where the dipstick is. Pumped the old ATF out through there, and pumped the 10W40 in. I think the capacity is 4.2 qts.
Joe
Old 07-10-2018, 01:59 PM
That’ll work... thanks
Old 07-10-2018, 11:00 PM
Also... yes I did replace the regulator membrane. Didn’t get a new spring with the kit
Which kit did you get? Does the replacement have a toggling center? Toggle side to side?
Old 07-10-2018, 11:43 PM
Not sure about that?? The kit I got was just a standard gasket, o-ring, and filter kit. I didn’t notice any toggling. I was able to rev it to 4K before it started popping. I pulled the flame arrestor at that speed and looked at the injectors. The starboard injector had a clean “umbrella” the port injector had a much heavier “umbrella” with a bit of trickling at the center.
Old 07-10-2018, 11:46 PM
Oh wait a minute... did you mean the regulator center metal? Yes the side opposite where the spring attaches did have a toggling piece. Sure makes compressing the spring a pain in the rump.
Old 07-12-2018, 12:48 PM
Cumminscj Cumminscj is offline
Boat: 86 Magnum Skier
Just to be clear you set the timing with the data connector shorted out and the rpms raised to 1,000 right?
Any error codes popping up?
1986 Marlin Magnum Skiier-sold
2000 Maristar 210VRS-weekend ride
1996 205 with LT1 cracked block-winter project
