Old 11-08-2018, 03:47 PM
BaLuna BaLuna is offline
Boat: Prostar 205V
Do you remember where you purchased them from?
Old 11-09-2018, 09:54 AM
bdiesel bdiesel is offline
Boat: 2003 X10 MCX
I haven't been able to find the invoice from when I purchased them, but this is where I got them from: https://fuelinjectorconnection.com/
I called them with the part number off of my stock and injectors and they still asked me to send them one. When they received it they called me back with options. It was a fairly quick turnaround.
Old 11-09-2018, 10:07 AM
Boat: Prostar 205V
Thanks for the info. I will get on the phone with them today. Huge help. Thanks.
Old 11-12-2018, 02:34 PM
Boat: Prostar 205V
So the folks at fuel injector connection recommended the following:
Does that look like what you put in?
I have been told that the fuel injectors seemed to be the problem but I have not tested them myself. Visually they look pretty corroded. What do you all think? Swap them out now because they look bad enough or try to get the proper tools and test them?
Let me know your thoughts/comments.
Old 11-12-2018, 04:29 PM
Boat: Prostar 205V
So Iíve decided to send the injectors to Rob Haack at Motor Man Fuel Injection for reconditioning. He will ultrasonically clean them then test them on an ASNU flow bench where they are tested for leakage, flow rate, and spray pattern. The coils are also ohm tested to make sure they are within spec. If any of the injectors fail he will let me know and give me the option to replace it with another injector. Filters and O-rings are also changed with the service. Fee is $20/injector.
With as dirty as the filters are Rob also recommended I clean the fuel rail, change fuel filter, and inspect fuel lines.
The website is
www.motormanfuelinjection.com
Iíll post once I get the injectors back, installed, and tested.
