Old 08-15-2012, 02:08 PM
badgerjfr's Avatar
badgerjfr badgerjfr is offline
Boat: '84 mastercraft
Smile magor issues... HELP!
hello all,
im a new member and recently bought a 1984 ss knowing it needed a lot of work. challange accepted. after working on this thing for a couple months im at a loss. fisrt ill tell you what i know has been done to the boat then ill tell you my problem.
rebuilt 351 windsor installed
new impellor
all new hoses and belts
new distributor cap and rotor and plugs
new fuel filter
rebuilt 4160 holley marine carburator
and timed the engine once
every time i change/replace something, we take it to the water to test it and always have the same issues.
i can get the boat to idle awesome. it sounds good, revs and relaxes on command. as soon as i put it in gear it boggs so bad and doesn't want to go anywhere. pumping the throttle doesn't help, nothing seems to work. then if i try to put it back in neutral, the engine dies. then it seems a little harder to get it to start again. im at my whits end
couple things i havent tried yet
replace coil
replace fuel pump
checked breather or anti-siphon valve
had a boating friend tell me my firing order may be off and causing the problem
basically im looking for some guidance, ideas, correct firing order? whatever anyone can spare. i would really like to get this thing running before evrything freezes over for the winter. please help.
thanks for your time
-jeff
Old 08-15-2012, 02:29 PM
oxberger's Avatar
oxberger oxberger is offline
Boat: Mastercraft, Stars&Stripes, 351w, grey and blue
badgerjfr, first welcome to TT. Second, it sounds like a fuel issue. I would start with checking the anti siphon valve then the fuel filters. There should be 2. One is inline before you get to the fuel pump, the other is in the bowl attahced to the fuel pump. I would also check the fuel pressure and flow into carb when going into gear. I hope that helps. The hardcore guys will chime in to help out with other things to check.
"The doctor said I swallow a lot of aggression... along with a lot of pizzas!"
Old 08-15-2012, 02:46 PM
Welcome aboard. This shouldn't be too tough to isolate where the problem is coming from and handle it. First need to figure out if this is related to fuel, electrical or your transmission. Fuel is the simple place to start. With the boat in the water and the doghouse open and the flame arrestor removed, you need to carefully inspect what is happening in the carb as it stalls and is hard to restart. You need to see that the choke blade is open all the way. You also need to determine if the carb is getting too much fuel and flooding out, or not getting enough fuel and running out of gas. After it stalls, watch to see if there is any fuel being squirted by the accelerator pump.
You can monitor spark at a spark plug wire or the coil wire with a timing light. Simply use duct tape to keep the trigger in and have someone watch to see what the light does in relationship to the engine.
Another possibility is a transmission/drive-shaft issue. If it is binding, it may not allow you to operate the boat. What does the fluid look and smell like? Is the level correct? Visually inspect the running gear under the boat for any damage.
Whew.......that should keep you busy for a bit. Hopefully not too busy to post a pic of this boat. We all love to see boat pics.
Old 08-15-2012, 03:46 PM
badgerjfr's Avatar
thanks guys. ill start with this. i dont think its the transmission, but i will check the fluid levels just to be safe. the prop looks almost new and all fins look original so i dont think its ever hit anything and when it is in gear not under good power the drive rod doesnt seem to have a wobble or anything, but i will double check eevrything just to be safe. thanks again. i will definately be ripping apart the fuel system and hopefully finding some issues that will solve my problems. heres a pic. and thanks again.
Old 08-15-2012, 03:54 PM
LYNRDSKYNRD's Avatar
LYNRDSKYNRD LYNRDSKYNRD is offline
Boat: 1987 PROSTAR 190
She's a beauty hope you get her squared away soon.
Old 08-15-2012, 04:39 PM
That is a great looking boat.
Old 08-15-2012, 04:46 PM
snork snork is offline
Boat: 07 xstar
Carb diaphragm
Old 08-16-2012, 01:56 PM
badgerjfr's Avatar
another quick question for all the boat gurus out there. does anyone have any favorite websites they visit to find parts for the "older" mastercrafts. a place with reasonable prices, and good customer service? thanks all.
Old 08-16-2012, 03:20 PM
Boat: 07 xstar
try skidim.com
Old 08-16-2012, 09:33 PM
Boat: 93 190
John 14:6
1984, engine boggs, idle, mastercraft
