  #281
Old 05-06-2017, 09:07 PM
tex's Avatar
tex tex is offline
Ready to go back in the boat!
Old 05-08-2017, 11:25 AM
h2oskifreak's Avatar
h2oskifreak h2oskifreak is offline
Boat: 1994 PS 190 TBI
Had my 1994 PS 190 out for the first time since doing the insulation. Much better noise level in the boat. In fact my 76 y/o father/driver says he can hear the Perfect Pass much better. All in all, nice upgrade for several reasons.
"One foot in the grave, one foot on the pedal, I was born a rebel" Petty
Old 05-08-2017, 11:15 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
I have not had mine out yet. I did order two more feet for doing the underside of my floor behind the motor box and the small piece around the ski pylon.
1996 Prostar 205 LT-1
Old 05-09-2017, 03:46 PM
flya750
Good Idea! I may have to add some to those areas as well.
Old 05-09-2017, 05:20 PM
jakethebt's Avatar
My real reason for doing the weird shaped part around the ski pylon is that the floor is not level. I noticed that when I set my motor box down, that section of the floor is a half in lower. I am going to shim it up but while it is out, I am going to insulate that too.
Old 05-09-2017, 10:30 PM
jakethebt's Avatar
Two feet worked awesome. I have just enough left to use on the small floor piece around the pylon. I don't think that part will come out with the seat in.
Old 04-03-2018, 10:54 AM
MasterCraftMike49 MasterCraftMike49 is offline
Boat: 2004 Prostar 197
Work in Progress
Replacing the insulation in my 04 PS 197. Old adhesive was a gummed up mess. Acetone and citrus stripper and about 4 hours or work. I'm installing the insulation this weekend. Will post more pictures.
Old 04-03-2018, 04:56 PM
paintpollz's Avatar
paintpollz paintpollz is offline
Yep, the process of removing mine was so brutal that I didn't even replace it. I hit it with acetone, citrus stripper, scrapers, sanders, and finally the wire brush on the drill was the most effective tool to finish the job.
There is absolutely zero difference with the stock sound deadening foam removed. So why would I put new sound deadening material in if that's what I'm used to? I am looking forward to your feedback though.
Kevin
Old 04-03-2018, 05:00 PM
paintpollz's Avatar
Fellow cowtown brethren, what's your feedback on the new sound deadening product? Worth the $250 or whatever it cost?
Kevin
Old 04-03-2018, 07:36 PM
jakethebt's Avatar
I did not even remove the glue. I scraped the old foam off and put the new down over top of it.
