Old 06-03-2018, 11:16 PM
paintpollz's Avatar
paintpollz paintpollz is offline
Boat: 2002 Prostar 197
just bought one of these buttons and a multi meter. hopefully will get to the button fix on Saturday.
Kevin
Old 06-04-2018, 11:07 AM
paintpollz's Avatar
Originally Posted by zsqure View Post
Here is where the momentary switch is wired into the ribbon cable that comes from the display. Be careful where you drill for the momentary switch. make sure the common trace is not cut (drilled through). I can't remember if it is a continuous loop or terminates at one of the switches.
zsqure - what tools did you use to separate the gauge faceplate from the housing? Is it glued together? I'll be doing this from a remote location so I want to make sure I bring everything I need.
Thanks
Kevin
Old 06-04-2018, 11:58 AM
slalomjunkie slalomjunkie is offline
Boat: NA
Thanks
http://perfectpass.com/?q=3event
The sea, once it casts it's spell, holds one in it's net of wonder forever - Jacques Cousteau
Old 06-04-2018, 12:15 PM
zsqure's Avatar
zsqure zsqure is offline
Boat: MasterCraft X-14, '09 Blue
Used the edge of a knife blade to work the two parts apart. Came apart eventually. was not afraid of boogering it up since a dual line upgrade was available from PP at the time. Still have it on my toolbox, why I do not know.
https://badges.fuelly.com/images/smallsig-us/302328.png
1988 prostar 190 SOLD
2001 Prostar 209 SOLD
Old 06-04-2018, 03:09 PM
88 PS190 88 PS190 is offline
Attachment 176425
Man those are some sexy buttons - its a shame PP doesn't provide a hook up for a remote wiring loom to have buttons elsewhere. Something like two of those mounted near the throttle would be great for adjustment on the fly for trick skiers etc.
Old 06-04-2018, 04:20 PM
paintpollz's Avatar
Originally Posted by slalomjunkie View Post
not a chance at $1349. I'm going to try and fix this one. I've been having some trouble with this one, but when I went into the settings the KDW and NN settings were totally outta whack. I've got those adjusted to factory spec, so as soon as I get it to turn on/off again it should work a lot better.
Someone that can't even make it around the buoys doesn't deserve a $1349 speed control system.
Originally Posted by 88 PS190 View Post
Man those are some sexy buttons\
that's the look I was going for
Kevin
Old 06-04-2018, 04:30 PM
Still in re: those buttons - are they marine momentary push buttons? Do you know where you got them from? I have this diesel tractor from the 1980's and I want to find something like those in both momentary and on/off for lights and horns - something nice and flush mounted.
Old 06-04-2018, 05:03 PM
paintpollz's Avatar
EBAY has a bazillion different ones. This is a momentary marine switch. link below:
https://www.ebay.com/itm/151508432443
Kevin
Old 06-04-2018, 05:22 PM
paintpollz's Avatar
thanks. assuming it's glued?
when you test the leads, were you using paperclips as a contact point to attach the mutlimeter to and then hitting the gauge buttons until you saw a voltage change?
Kevin
Old 06-04-2018, 09:03 PM
zsqure's Avatar
I believe all I did was to ring out the circuit for continuity. I determined the domed switch was not making contact because there was a break in the material. If I jumped it with two straight pins stuck into the traces on either side of the switch it worked. At that point I traced the circuit back to the connector and its respective pins.
