Old 01-27-2013, 06:23 PM
uplander uplander is offline
Boat: MC 2002 X30
boat lift with v-drive
will a v-drive fit on a normal boat lift . the place I am looking to rent has the square tank style lift with bunks.
Old 01-27-2013, 06:34 PM
Table Rocker's Avatar
If the bunks aren't pretty high above the tanks, you might drag your prop and rudder off on the frame of the lift. It just depends on how the lift is set up.
'96 ProStar 205 SD LT-1
Old 01-27-2013, 06:52 PM
Boat: MC 2002 X30
that was my concern - I will try to post a pic of the lift
Old 01-27-2013, 07:04 PM
Boat: MC 2002 X30
here is a pic of the lift
Old 01-27-2013, 07:38 PM
CC2MC's Avatar
CC2MC CC2MC is online now
Boat: 2005 x-10
What Table Rocker said. This looks more like a pontoon boat lift. It looks like it has low bunks and they look to be pretty close together, making it hard to line up just right where your prop is between the bunks. I would not even risk it. Also, you do not know what the capacity of that lift is. How long will you be renting the place?
Old 01-27-2013, 09:16 PM
Boat: MC 2002 X30
we rent for one week
Old 01-27-2013, 09:47 PM
jafo9's Avatar
jafo9 jafo9 is offline
Boat: 2002 X30 LTR
no way would i put my MC on that lift. that lift looks identical to what i have my pontoon on. my pontoon has standard outer logs with lifting strakes and a larger center log for performance. thats the way that lift is setup. there is no way an inboard will work on that.
Old 01-27-2013, 10:00 PM
Boat: MC 2002 X30
thanks guys, I gues the only other option would be to drop the lift and leave it down for the week
Old 01-28-2013, 08:08 AM
ChandlerR ChandlerR is offline
Boat: 2015 Super Air Nautique 210
On most lifts the bunks are adjustable. Might be worth a try to adjust or modify it.
Old 01-28-2013, 09:25 AM
gts-20's Avatar
gts-20 gts-20 is offline
Boat: 2008 Prostar 214 w/ mini tower mcx
We rented a house on Lake Austin a couple of summers ago. . It had a lift that we used for almost week. I don't think it was ideal, but with a lot of attention to where the intakes/speedo wheel, and underwater gear were, and how far forward the boat was, it worked for the short time we were there. I wouln't have used it for more that the 4 days we were there though.
