Old 07-11-2018, 06:07 PM
Waterbucket1 Waterbucket1 is offline
Boat: 2015 X23
X23 wont start
Started to get the boat out this afternoon and just as I pushed it out of the dock I realized that it would not start. Jiggled the throttle a little and it fired up. Wanted to be safe so I shut it down to see if it was just a fluke and no joy. Could not get it to start again. Played with it about 10 min and had it try to start one time in that period.
I fell pretty sure that it's the sensor on the backside of the throttle.
Anyone have any other ideas or the part number?
Thanks
Chuck
Sent from my SM-G965U using Tapatalk
Old 07-12-2018, 08:22 AM
MattsCraft's Avatar
For sure sounds like the throttle position sensor - Mine every once in a while will stick (Not sense Neutral position) But the jiggle works!
Try spraying down in & around the base with some electronics cleaner, might help.
Sorry, don't know the part number, but your should for sure!
Old 07-12-2018, 01:45 PM
Boat: 2015 X23
Swich picture
Here is a picture of the switch that I suspect. Anyone know what it is called?
It operates by way of a magnet on the backside of the throttle, behind the side panel at the driver's seat.
Thanks
Chuck
Old 07-12-2018, 02:14 PM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
What you have is a throttle position sensor that is $20 and it disabled a $120,000 boat. Good job Mastercraft
Old 07-14-2018, 08:14 AM
Boat: 2015 X23
Fixed...
Ended up being a $3.00 starter relay on top of the engine. It was just intermitting enough that I thought I was doing some good by jiggling the throttle. When in fact it was just the relay breaking down.
Well I learned a lot about neutral position switch, dash switch and throttle sensor.
Thanks for those who chimed in.
Chuck
Old 07-15-2018, 08:07 AM
MattsCraft's Avatar
Glad it was an easy/cheap fix!
