Old 05-20-2015, 12:17 AM
ryan_kc13 ryan_kc13 is offline
Boat: x30
Give me the lowdown
So we took out our new to us 2008 MasterCraft X30 out for the first time yesterday. When we started the boat the temp was at 220 but when we started to go it lowered to normal temperatures. Also do you run with both batteries on?
For the perfect pass do you just put it in the mode you want and speed you want and give it throttle?
Thanks and for surfing what do you have the trim at and wakeboarding?
Thanks and if you have any other tips or things to tell me let me know Thanks.
Old 05-20-2015, 12:29 AM
you were at 220 at idle?
Old 05-20-2015, 12:32 AM
Boat: x30
Yes and then gave it some throttle and went down to normal operating temperature.
Old 05-20-2015, 12:35 AM
you may want to check the impeller.. when is the last time it was change - and or your t-stat.. that seems high even at idle.
Old 05-20-2015, 10:15 AM
Boat: x30
It just got back from it's 100 hour service at the local dealership so I'm not sure because they said they changed the impeller.
Old 05-20-2015, 10:18 AM
WakeWise's Avatar
WakeWise WakeWise is offline
Boat: MasterCraft X-30 2014, MasterCraft X-10 2004, Correct Craft SV211 2004, Centurian T-5 2001
Run with the setting at 1 battery. PP set the speed at idle. Throttle past that speed and leave it. PP takes over at that point.
Old 05-20-2015, 10:40 AM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
Regarding the temp. . . after running, did you also check it back at idle? Normally, the temp will go up a bit but 220 seems pretty darn high--if it keeps happening I think you need to look for some kind of obstruction that reduced flow at low RPM.
For Perfect Pass, you should get a confirmation beep when the PP takes over so you'll know when it's in command.
I have a dual battery setup (starter and house) and use an automatic relay that joins both batteries when the motor is running. The idea is that this charges both (or one) from the alternator. With the motor off, the connection is broken so I can run my stereo and accessories off the house battery without fear of draining the starting battery. I like this automated switching for that reason. I guess you can achieve the same using a manual switch.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 05-20-2015, 07:14 PM
Boat: x30
So put the switch on 2 or 1 battery while moving. I will check temp later this weekend when I get out to the lake.
Old 05-20-2015, 08:08 PM
Table Rocker's Avatar
Table Rocker Table Rocker is online now
If it was your first outing of the year and you dry block winterized, it can take a bit to fill the block with water. I wouldn't worry about it yet.
'96 ProStar 205 SD LT-1
Old 05-21-2015, 12:06 PM
Kweisner's Avatar
I agree--my earlier suggestion to check temp AFTER running would tend to confirm Table Rocker's post. His answer is much more to the point!
2008, batteries, perfect pass, trim, x30
