Old 04-19-2018, 01:17 PM
Vogey Vogey is offline
Boat: Carrera 7m ss 1978 454 trs
Gt40p heads on 188hp mercruiser 302
I have 77 century raven (20' fiberglass closed bow) that has a omc outdrive. The 302 wad replaced at somepoint with a 188hp mercruiser. Last time out i noticed the oil was milky. If im doin head gaskets no reason to not throw a set of gt40p heads on and a 4 barrel. My question is this has anyone done this? Did the spark plugs clear stock manifolds?
Old 04-19-2018, 02:24 PM
Pretty sure there is no restriction with the OMC exhaust manifolds but can't guarantee it. if you need a marine Holley 4160, I can hook you up.
COSTOM DECALS - EMAIL FOR MORE INFO
Old 04-19-2018, 11:14 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
I do believe that you’ll be ok.
Old 04-19-2018, 11:19 PM
Boat: Searching
Just be careful with how much carb you are putting on that 302. The 351 and the 302 both have a 4” bore but the 302 only has a 3” stroke which mean you can over carb it real quick. But if you carb it corrrectly you’ll definitely have jump in hp with those heads.
Old 04-20-2018, 12:06 AM
I set up 600 cfm 4160ís with proper jetting to work with a 302 with an upgraded aluminum intake. I also have a 450 cfm 4160 I can rebuild for this.
