Old 04-13-2018, 01:25 PM
Jared Jared is offline
Boat: 2016 X-10
Tire Help
Issue resolved
Old 04-13-2018, 01:35 PM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
Originally Posted by Jared View Post
In order to fit my X-10 in my garage, the dealer customized my trailer with a local shop (adjusted the torsion axle, raised the prop guard, low profile tires). I had been running the tires at the max pressure and during its annual checkup the center treads were badly worn and needed to be replaced to make it through summer.
My problem is the dealer can't find those tires anymore to replace them (ST195 75 D14). They tried a similar tire but they left only 3/4" to the wheel well which would be a problem. I'm boat less until we figure something out. Lowering the axle to create room isn't a viable option as I am limited to getting through a 6'-11.5" garage door opening.
Any help out there? I'd prefer not to have to deflate them to pull in and out...
Also thoughts on tire pressure? I'd always been taught to run them at max pressure when under load and I'm guessing the X-10 with trailer is at 6500lbs minus tongue weight when fueled up.
Peter, Where are you?
They are available all over.
https://www.tires-easy.com/195-75-14...irecode/519307
https://www.amazon.com/75D14-Nanco-S.../dp/B0081E1ACO
Boat: paddle
Oh, there you are.
Old 04-13-2018, 01:37 PM
Originally Posted by Maristar210 View Post
Oh, there you are.
I'm around, but way too busy. This all work stuff is for the birds.....
Old 04-13-2018, 02:15 PM
Boat: 2016 X-10
Thanks Peter! Any thoughts on the tire pressure? Where should we be running our tires at?
2016 Metallic Blue X10
ex 1998 Sportstar 19
Old 04-13-2018, 02:56 PM
Tire Help
You are welcome.
When the proper tires are used, max psi is my recommendation. In your case, you might try a little less pressure. Keep in mind the smaller tires are narrower than the ST205/75R14 tires that came stock, thereby having a smaller footprint, so there is more load on the tire.
Old 04-13-2018, 03:57 PM
jtkeller jtkeller is offline
Boat: 2018 X26
Adjust tire pressure to get even wear.
