Old 08-20-2018, 03:17 PM
ualgrizz ualgrizz is offline
Boat: mastercraft prostar 190 1991
No Electrical power
Hey guys:
Just put my 91 ProStar together. Went to start for the first time in a couple of years. New battery. Turned the ignition switch on and all of the components worked. Went to start and the starter barley turned over. I assumed weak battery and tried to charge. Now everything is dead. Any suggestions?
Thanks, Grizz
Old 08-20-2018, 03:25 PM
CrashCourse316 CrashCourse316 is offline
Boat: MasterCraft, 280 SST, 2005, Twin 375 Crusader
well.....start at battery and work away from it.
Do you have power on the gauges?
if so does it say 12v ish at the battery gauge?
Check power at the starter cables. reading 12v? run a 12v directly to the starter and give it the ol' 12v bypass touch to see if it goes full power.
ummmm.....battery cables cleaned and tightened down properly?
have you made your SO or wife(or both) angry lately???
Sam
Website: www.SteadyPass.com
Email: [email protected]
Boat: 2005 Maristar 280 SST Twin Crusader 375
Old 08-20-2018, 03:27 PM
Hey was getting nothing at all after trying to charge. Going to get some new battery connectors to see if that helps.
Thanks
Old 08-20-2018, 03:32 PM
take the battery in and have it load tested... I just took mine in my volt meter said 13.5v.. but I took it in and when they put a load on it went to 9.86v just like that... weird as usually if a battery reads 13.5v it is good.. when i turned the key on my tractor it would just make a bunch of noise...
Old 08-20-2018, 04:05 PM
Thanks
Yea if that is the cause you'll know real fast. have you tried licking the battery to test?
Sam
