Old 10-07-2016, 12:05 AM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
Trailer troubles
I have a 2006 star with a trailer problem... see below
The tire is prematurely worn on the inboard side. I thought it might be a loose wheel bearing but it seems tight. As I carefully look at the photo it appears that the torsion axle has a slight angle to it... does anyone know what this is ...or.. has anyone seen this before?
Old 10-07-2016, 12:12 AM
neil.anderson63's Avatar
Boat: 2007 X2
Yip, I had same problem. Took my trailer in to a great trailer shop and had it aligned. Nothing on mine was bent or broken. Just one tire wearing big time. I put a new tire on to replace the worn one, the rest were very low miles. Been running 2 years since aligned, no excessive wear.
Old 10-07-2016, 12:47 AM
craig3972's Avatar
Do you know if they replaced the rubber inside the torsion axle?
Old 10-07-2016, 11:31 AM
Boat: 2007 X2
My torsion arms were causing the problem. I had a couple long trips, 1 across Wyoming in the early spring. Roads were in bad shape. Seemed like every bridge joint was like jumping a curb. Took the trailer shop about an hour to align all 4. I think it was short of $150. I put the new tire on right before I pulled to the trailer shop.
Old 10-07-2016, 01:04 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Did they make any preference if the trailer was loaded or unloaded (boat on or off)? I need to do this for my trailer.
- Jeff
1994 205, LT1
Old 10-07-2016, 02:29 PM
Boat: 2007 X2
Boat on trailer...
Old 10-07-2016, 06:31 PM
Boat: 2006 X30
The problem is the alignment, not the torsion rubber. Find a good shop and get the axles bent into alignment.
