Old 11-19-2014, 10:57 PM
mattdda's Avatar
mattdda mattdda is offline
Boat: SHOPPING
Don't suppose you have a prop pulling kit...? Makes it super easy, safe, and damage free. Check out www.skidim.com.
SHOPPING
03 X 30
90 Supra TS6m Comp
PROPS to: www.skidim.com
Old 11-19-2014, 11:26 PM
rbuss4
Guest
Posts: n/a
You need a prop puller to put pressure on the prop so it will pop off. Keep the nut on the end of the shaft to keep the prop from flying off when it goes. The best was to get it to "go" is to heat the heck out of it with a blowtorch. after about 10 min of evenly heating it, it will pop/fly off. If you dont have a prop puller, it is gonna be tough. YouTube videos are a great help.
Old 11-19-2014, 11:29 PM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
take the nut all the way off. use a ball peen hammer to tap on the hub of the prop, it should only take a couple of hits to vibrate the prop loose from the splined shaft. once loose, you can turn the rudder all the way to one side and slide the prop off the shaft past the rudder. you only need a puller if you are using the old style tapered or keyed drive shafts.
easy peasy lemon squeezy
Old 11-19-2014, 11:47 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
OP already indicated the prop was loosened on the shaft.
No puller, nor hammer, no blowtorch needed.
He needs help getting it past the rudder.
Since the rudder is offset, turn it so that you have maximum clearance from the end of the driveshaft. Rotate the prop as you pull towards the stern -- I forget which way -- and try angling the prop to one side and down once it's mostly off the splines. It should sort of rotate itself off the shaft.
At least that's what works on my X2.
Old 11-20-2014, 12:07 AM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
This. Rotate it as you pull it off. It will work. It's like a jigsaw puzzle
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 11-20-2014, 06:39 AM
CantRepeat's Avatar
You might need to remove the steering cable from the tiller arm so you can turn the rudder far enough to gain the clearance needed to get the prop off the shaft.
Tim
Old 11-20-2014, 08:44 AM
CantRepeat's Avatar
I posted a suggestion in the other thread you posted about this.
Tim
Old 11-20-2014, 09:28 AM
jgraham37128
Guest
Posts: n/a
I have a 2010 X2 same thing. It only comes off when you turn the wheel all the way in one direction. I beleive it's left but not positive.
Be patient and don't get in a hurry turn the wheel all the way and start spinning the prop. It will fall out on it's on but it's a very small window. I just started spining it around and it fell partially thru then I pulled it out the rest of the way.
Same thing when placing it back on, it takes some time getting it at the right angle and etc... but it will work.
Old 11-20-2014, 09:48 AM
wilhelmwake's Avatar
wilhelmwake wilhelmwake is offline
Boat: 2019 X-Star Ilmor 6000GDI RadNorth Edition
AnDo if nothING else works, just remove the rudder completely. That is not a hard task, just if you are doing it by you self, place something under the rudder that you do not drop it on the floor and damage it.
-=MasterCraft All The Way=-
2019 MasterCraft X-Star
2017 MasterCraft X23
2015 MasterCraft X23
2007 MasterCraft X45
2009 Malibu WAKESETTER VLX SS
2005 MasterCraft X-Star
2004 Tige 20v
1995 MasterCraft ProStar 190
Old 11-20-2014, 11:20 AM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: 2015 X20 SS
Prop Master
I had the Same Problem.
If you can't turn the Rudder far enough left or right..
Remove the cable/Ram from the Rudder Arm..
NUT and Bolt in Left of photo
My boat is an SS and Has Hydro Steering...so this is a must
2015 X20 SS GEN2 6.0
2016 G21 Coastal
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
