Old 07-20-2018, 04:20 PM
Originally Posted by ldelosreyes12 View Post
Where is the right place?
Anywhere upstream of the raw water pump. Tap into the hose and then you have circulating water when the engine is running.
Don't forget to drain the feed hose to the seal in the winter. You need to plug that hose if you put in antifreeze or it will just run out the hull when winterizing.
You are on the right track. Just a tad bit off on the tie-in. No big deal at this point in time. Just put a straight piece back in place of the tee fitting and move on.
John 14:6
Old 07-20-2018, 04:56 PM
ldelosreyes12 ldelosreyes12 is offline
Boat: 2005 X10 - MCX 5.7L
Water line
Thank you!!!
Old 07-20-2018, 08:19 PM
wetterthebetter's Avatar
wetterthebetter wetterthebetter is offline
Boat: 1980,1984, Stars and stripes,1971 AquaCraft Drag boat, 1991 American Skier
Location: northern Sierras between Lake Tahoe and Sacramento
What is the significance over Dripless vs Stuffing box packing?
Old school box just drips 5-6 drops a minute.
GFO packing material, this is the "Gore + Teflon+ Graphite" this packing is Virtually dripless
Sorry but I don;t get it.
Please explain,thank you
Old 07-20-2018, 08:28 PM
Table Rocker's Avatar
Originally Posted by 88 PS190 View Post
Ha well add a second hose clamp to each and try it off a bucket. Water should come out around shaft. If it isn't you'll have to reroute.
I would expect the raw water pump to be pulling in air from the dripless and have a problem priming from the bucket.
'96 ProStar 205 SD LT-1
Old 07-21-2018, 11:48 AM
88 PS190 88 PS190 is offline
If expect that too.
Old 08-15-2018, 01:15 AM
Smogg's Avatar
Smogg Smogg is offline
Boat: 2002 X-10
Here is a good read on the subject:
http://www.pbase.com/mainecruising/stuffing_box&page=1
