Old 06-25-2010, 10:23 PM
spooln7
Where to buy rear upper bench upholstery (complete)
Hi, I have a 1996 Prostar 205 and lost the rear upper upholstery bench thing that sits right over the fuel tank. I'm not sure what to call it but it is held on by 3 nuts on the underside of the fiberglass over the fuel tank. I attached a picture if that helps. Does anyone know where i can buy a new one?
thanks,
Craig
Old 09-21-2010, 09:42 AM
MC205's Avatar
MC205 MC205 is offline
Boat: 1996 PS 205
Your local upholstery shop should easily be able to fab that for you.
-Aaron
RED 1996 Prostar 205
Indmar 350 TBI
Acme 541
PerfectPass Stargazer Wakeboard Edition
Old 09-21-2010, 08:07 PM
Boat: 95 PS 190 EFI
I need that piece as well for my '95 PS190. If you find factory skins, pls let me know.
If one day you're asked:
Will you say:
It's time to SKI.
Old 09-21-2010, 09:05 PM
dmminfla's Avatar
dmminfla dmminfla is offline
Boat: 1997 PS 205 5.7L 275 HP TBI
I had mine re-covered. I think it came out close to original.
Old 09-22-2010, 09:05 AM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
Quickest way is DIY.
Old 09-22-2010, 09:34 AM
MC205's Avatar
Boat: 1996 PS 205
coz,
Did you use marine grade plywood? Did you glass it?
-Aaron
Indmar 350 TBI
Acme 541
Old 09-22-2010, 09:44 AM
thanks,
Craig
The panel may have had plastic retainers that push into a hole in the fiberglass, then the threaded stud has a nylock nut and washer below. If the stud was threaded into a T-nut, it may have backed out, which means red thread lock should be used this time. I wouldn't use anything like that on the nut, in case it needs to come out. You would want to use T-nuts that can be screwed into the panel, so they don't push out of the hole. An alternative is to use a threaded insert, but if the wood rots, that will basically fall out. The panel can be fabbed up by a good upholstery shop.
Old 09-22-2010, 09:57 AM
mayo93prostar mayo93prostar is offline
Boat: 1993 Prostar 190 Blue Stars and Stripes, Powerslot
Coz, Why did you have to replace yours? Did you shave the foam down on an angle along the back? I am curious. It looks like a nice job.
Spooln, you would be hard pressed to find a replacement from a dealer or other shop. I agree with others here that you and/or an upholstery shop will have to build it.
1993 Blue Stars and Stripes Prostar Powerslot 351HO
Mastercraft: Face It - If you are not a good skier behind this boat, you are not a good skier.
Old 09-22-2010, 10:41 AM
coz's Avatar
coz coz is offline
coz,
I used regular ply and I didn't glass it but I did polyurethane the heck out of it. The reason I had to replace it was because I lost it on the freeway somewhere between Phoenix and the colorado river and no I didn't shave it, my neighbor (upholstery guy) wraped just like you see it. He did say the next time I do one (hope never again) to leave about a 1/2" over hang of foam all the way around before wraping it.
Old 10-20-2010, 11:45 PM
rslong50 rslong50 is offline
Boat: 205
Sundeck replacement
So my sundeck flew off somewhere between San Fran and Sacramento. I just realized that one of the plastic retainers on the boat is sheared off and it took some fiberglass with it. Are these nuts/retainers vital to keeping the sundeck in place or is there an alternative route I can take? Thanks for your input.
