Old 09-20-2010, 07:41 PM
atlfootr's Avatar
atlfootr atlfootr is offline
Boat: Barefoot 200 MasterCraft 1993 ProV200 Outboard
Originally Posted by east tx skier View Post
Just for clarity's sake, he's talking about paint can openers.
In case you don't who clarity is, here's her photo!
jimmer2880 jimmer2880 is offline
Boat: 95 PS 190 EFI
Send a message via AIM to jimmer2880
I screw a deck screw into the rubber part, around the hub, then grab the head with a pair of plyers and pull.
If one day you're asked:
" How did you spend your time here on Earth?"
Will you say:
"I kept a crabgrass free lawn"
It's time to SKI.
Old 09-21-2010, 10:03 AM
ahhudgins's Avatar
Spray some WD-40 in the pump housing, turn the motor over a few times and grab the impeller with a pair of channel locks and it will slip right out.
Yup, the WD-40 works every time for me.
You shouldn't have to say this, but don't grab the impeller while you are turning the engine over. I watched a guy change out an impeller on his old 78 S&S and then he tried to check the belt tension with his fingers....while it was running. It wasn't pretty.
Old 09-21-2010, 11:15 AM
#47of100TeamMC's Avatar
#47of100TeamMC #47of100TeamMC is offline
Boat: 2002 Tournament Team Edition Prostar 197
Send a message via MSN to #47of100TeamMC
No need to lube it up...she won't care. Just take 2 needle-nose pliers grab slats on opposite sides of each other and give them a tug. Pops right out. Then when you go to put it back in, put some white lithium grease on the shaft before you slide it in. Easy Peasy Japanease.
2002 ProStar197 Tournament Team Edition (yes it's Red)
*LQ9, Powerslot,Perfect Pass,Zero Flex tower,Heater
Old 09-24-2010, 09:33 AM
gr82bgreen's Avatar
gr82bgreen gr82bgreen is offline
Boat: 1989 Prostar 190
Originally Posted by jlbenzo024 View Post
I need to change my impellar and im just wondering what the best way to get it out is without the impellar tool. Thank you.
because I have a v drive and have no room or sight I use a large stud extractor and vise grips.
Old 09-24-2010, 01:31 PM
Barefooter92's Avatar
gr82bgreen:
Do tell...Do you have to stand on your head too?
Old 09-25-2010, 11:01 AM
gr82bgreen's Avatar
Originally Posted by Barefooter92 View Post
gr82bgreen:
Almost. It's not too bad as the side panels beside the engine come outand I do have room to kneel beside the engine.
