Old 03-01-2013, 12:29 PM
EarmarkMarine's Avatar
Boat: TBD
A couple questions...
What grit sand paper do you recommend to sand the fiberglass?
Would "3M/1 gal. Bondo-Hair long strand fiberglass reinforced filler" from Autozone be a sufficient product to use to attach the board to the fiberglass?
Try 80 grit or courser. Just enough to scar an otherwise smooth surface to get a good bond.
Anything with fiberglass strand has some structural integrity and good adherence unlike a plain body filler. And, mix in a polyester resin 50/50. Don't forget the catalyst.
If its the hull surface use intermediate blocks and not the board/panel direct.
David
Earmark Marine
www.earmarkmarine.com
Old 07-19-2015, 07:58 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Alright bringing this up from the dead. As the wetsounds amps accumulate, I'm running out of places for them to go in the 25. Thoughts??? Wetsounds syn2/HT1 and future SD4 need a place to go along with the stock 600/6..
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 07-20-2015, 08:19 PM
ZachDaddy's Avatar
Here is how mine looks:
Old 07-20-2015, 08:21 PM
el Dax's Avatar
el Dax el Dax is offline
Boat: Mastercraft, Prostar 205, 1996, 3fiddy
During installation...
Old 07-20-2015, 08:24 PM
MC25's Avatar
Are you guys screwing these straight into the fiberglass? That SD6 is MASSIVE. Ideally I'd like to have the same set up as zachdaddy.
-Aric
Old 07-20-2015, 08:28 PM
el Dax's Avatar
Mine is bolted through...big washers, SS bolts, and nylon locks. And yea, Zach's setup is pretty sweet. I can't even imagine, mine is stupid loud.
Old 07-20-2015, 08:41 PM
ZachDaddy's Avatar
The SD6 is in the fiberglass with 1/2 stain steel screws...the sub amps are on a carpeted piece of mdf thats 1/2 inch thick. Its built up on one end and flush on the other to make it plum.
I too worried about the other side but no problems with the fiberglass thickness
Old 07-20-2015, 08:46 PM
MC25's Avatar
What do you mean bolted through????
I'll have 2 JL 10W3v3's in a ported box, the 4 JL tower speakers have a wetsounds syn 2 on them, and the 4 in boats have a 600/6 JL on them.
Future plan will be 4 rev 10s with an SD 4 running them!
-Aric
Old 07-20-2015, 09:54 PM
BudmanV24 BudmanV24 is offline
Boat: 2006 MasterCraft XStar
That section of the boat is double wall. It's got a large panel sandwiched between layers of the fiberglass in the top deck to allow mounting amps. You don't need to pre-drill the holes imo. Regular sheet metal screws self-tap just fine.
2006 MasterCraft X1 - Sold
2003 Sevylor Caravelle 7' 6"
Old 07-20-2015, 10:31 PM
MLA MLA is offline
Boat: pontoon
i hope you mean SD-2
