Old 06-16-2018, 01:29 PM
neil.anderson63's Avatar
Boat: 2007 X2
Originally Posted by Waistline00 View Post
Ya, I have 2 upside down (kgb and 1 other) and one right side up. I'll look at the rotation of the pump when I hit the switch and see which way it's running. Thanks
You can driveway test this by putting water in your tanks through the vent. You won’t need much water, just till you hear the pumps prime up and push water out the bottom of your hull.
Old 06-18-2018, 05:22 PM
Jameylee Jameylee is offline
Boat: 2008 Mastercraft x35
What are your RPMs at when filling? Sometimes i put my boat in gear and move forward as I'm filling. It helps push the water to the pumps
Old 06-18-2018, 05:41 PM
Waistline00 Waistline00 is offline
Boat: 2007 mastercraft x-45
Figured it out. Pulled the lines off the pump, they were on the right directions, tried blowing into the line going to the ballast tank, totally plugged. Opened the ballast hatch and found the line totally kinked off. Easy fix. Turns out someone for some reason took the block to keep the tank in place out, so then the tank slid back and pinched the hose.
Old 06-18-2018, 05:43 PM
GiantDO@X35's Avatar
[email protected] GiantDO@X35 is offline
Boat: 2012 X35 6.0 Ilmor
Wow! Nice work. Add that one to the memory bank
Old 06-18-2018, 06:50 PM
Boat: 2007 X2
Nice CSI skills! Little hose repair and install the block. Good to go.
