Old 04-21-2009, 11:40 PM
CODY_YARBER07's Avatar
CODY_YARBER07 CODY_YARBER07 is offline
Boat: 1983 Mastercraft 19 Skiier Stars and Stripes
Send a message via MSN to CODY_YARBER07
What To Power Wetsounds Pro 80's With?
How do you all power your Wetsounds Pro 80's. I bought a Cadence Amp that is 300 x 2 (at 4 ohms) but I'm having second thoughts. I sort of want to power my WETSOUNDS with a better brand name amplifier. Not sure how much difference brand name makes. Someone help me out!
-Cody
1983 Mastercraft Stars and Stripes
351 With Powerslot
Old 04-22-2009, 04:23 AM
icw88
Guest
Posts: n/a
I have 4 Pro80s and I have them on a Huge 4 Channel amp running Stereo and they are retarded loud and are crystal clear. You should have a big clean amp if you want to get the best use out of them.
Old 04-22-2009, 07:23 AM
proporjet proporjet is offline
Boat: Moomba, Outback LS, 2003, Indmar 330HP,
88,
What is a huge 4 ch AMP?
MFR? RMS power? I'm considering options as well for driving 2 80's and 2 60's. Of course
WetSounds recommends their SYN2 and I have heard that their 'stuff' is good. Connect 2 Left and 2 Right in parallel to yeild a 2 ohm load to each channel of the amp and then you get 175W to each pair. Doesn't sound like the best option but that is what they recommended...
Old 04-22-2009, 07:33 AM
mosby mosby is offline
Boat: Mastercraft x-30, 08, 6.0
My friend has (1) 485 and a pair of 80's and he had a JL 6ch bridged on them just to hear them play and it sounded .....good but not what you expect. He had a 850.2 Kicker and hooked it up and it was night and day difference. The more power the better. I got a pair of NVS Entity's and I just got the new 750/1 MHD JL amp for them. I was prepared to only use 1 of the NVS's on the 750 but 2 look better lol. My advice... JL MHD, Kicker 850.2, Alpine PDX4.150 plus the Alpine's and the JL's are stackable and the JL has a seperate level control so you can control the 80's as you desire.
Old 04-22-2009, 07:49 AM
D3skier's Avatar
D3skier D3skier is online now
Boat: MasterCraft 197 TT 2007
which Cadence amp did you get? I've got the ZRS2002 and my pro80's ROCK! I've even managed to submerge it twice already due to stupidity and the amp is still kicking strong. Cadence told me even if I got it wet and it broke they'd still cover it under warranty. This is one of the brand names that Wet Sounds suggested and I called Cadence directly to find the right amp for the speakers and couldn't be happier with my decision.
1998 Stingray 180LX
2000 Infinity ZX-1 good riddens
2003 Prostar TT 197 sold
2007 Prostar TT 197.....special delivery from the dealer 3/18/08 sold 6/7/11
Old 04-22-2009, 09:48 AM
I got the Cadence TXA-3004. The specs say it supplies 300 watts x 2 (at 4 ohms) which would be more than enough but I just worry that the wattage of these amps are grossly overrated. I have always had brands like Infinity and JL but if Cadence is good then im fine with it.
351 With Powerslot
Old 04-22-2009, 10:08 AM
D3skier's Avatar
looks like if you bridge the amp you'll have enough power. If I were you, I'd call Cadence directly and get their opinion on that amp and possibly see if a different amp would give you better quality sound from these speakers. I connected a Lanzar Vibe 600w amp to it and wasn't even enough power to push them with any decent sound or quality.
TXA-3004
4 CHANNEL HIGH POWER AMPLIFIER
SPECIFICATIONS:
* 4 Ohm RMS Power: 4 x 75 Watts @ 13.8 Volts
* 2 Ohm RMS Power: 4 x 150 Watts @ 13.8 Volts
* 4 Ohm Bridged RMS Power: 2 x 300 Watts @ 13.8 Volts
* Frequency Response: 20Hz - 30kHz
* Damping Factor: >200 @ 100Hz
* S/N Ratio: >100 db
* Channel Seperation: >65dB
* Minimum THD: <0.05%
* Dimensions: 17" x 9.2" x 2.12"
ZRS-2002
2 CHANNEL HIGH POWER STEREO AMPLIFIER
SPECIFICATIONS:
* 4 Ohm RMS Power: 2 x 200 Watts @ 13.8 Volts
* 2 Ohm RMS Power: 2 x 400 Watts @ 13.8 Volts
* 4 Ohm Mono RMS Power: 1 x 800 Watts @ 13.8 Volts
* Frequency Response: 10Hz - 40KHz
* Channel Seperation: >65 dB
* Minimum THD: <0.044%
* Input Voltage: 200 mV - 8 Volts
* Dimensions: 20" x 9.4" x 2.4"
Wet Sounds specs
Specifications:
RMS Watts: 200
Peak Watts: 400
Impedance: 4 ohms
Frequency Response: 20Hz to 20KHZ
Sensitivity: 90 db at 1watt/1 meter
Mid Bass: 8 inch EFG™ cone woofer with polyurethane surround
High Frequency:Pro-Axial™ Driver. Coaxially mounted Titanium Diaphragm High Output Horn Loaded Compression Driver
Hang Weight: 13.5 lbs
Hang Height 13 inches
Height: 11.5 inches
Width: 10 inches
Depth: 14 inches
1998 Stingray 180LX
Old 04-22-2009, 10:13 AM
TXA-3004
SPECIFICATIONS:
ZRS-2002
SPECIFICATIONS:
It seems like the TXA-3004 has more power than the ZRS-2002 which doesn't make any sense to me because the ZRS is alot more expensive. I guess I am going to call Cadence.
351 With Powerslot
Old 04-22-2009, 10:18 AM
D3skier's Avatar
it only has more power if you bridge the amp
1998 Stingray 180LX
Old 04-22-2009, 10:21 AM
I just got off the phone with Cadence and they said the TXA-3004 is so cheap because it has been discontinued. That makes me feel better. I just don't want to have really nice Wetsounds speakers and drive them with a crappy underpowered amplifier.
351 With Powerslot
amplifier, audio, pro 80, speakers, wetsounds
