Old 04-20-2017, 01:21 PM
NTXCEDARCREEK NTXCEDARCREEK is offline
Boat: MASTERCRAFT/XT23/2017
2017 XT23 Ballast Timers
I have a new XT23. Can anyone help me with the fill/empty times, so I can adjust the times in settings.
Old 04-20-2017, 01:47 PM
Mastercraftdave's Avatar
Boat: 2015 X23 SS 6.2L
You can change all of the timers on the screen in the settings.
Old 04-20-2017, 02:03 PM
Yes sir, I understand that. I am asking if anyone would share their fill/empty times. Thank you for your quick response. That's why I like forums......
Old 04-20-2017, 02:11 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
just set them to 10 minutes, then time how long it actually takes. done
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 04-20-2017, 03:10 PM
I think my middle Ballast is 5 and Half minutes and my rear is around 7. But that is on an X23.
Aric make a great point. Set it at 10 minutes, and set a watch then you will know for sure.
Old 04-21-2017, 01:50 PM
JBaker's Avatar
JBaker JBaker is offline
Boat: 2017 XT23 5500
IIRC these are very similar to the XT23, maybe slightly less than that for the rear. I think it's like 5:30 and 6:30. There is no harm in running over.
Old 04-21-2017, 02:12 PM
MC25's Avatar
Times aren't always the same though. Engine off, engine on, idle, at speed, etc.
-Aric
Old 04-21-2017, 03:27 PM
LDA6339 LDA6339 is offline
If the empty time was too long could it not damage the impeller from spinning with no water?
2016 X-30 6.0L
"YoU CaNt FiT 4 Rev10's oN a ZFT4"
2017 Nissan Maxima SL
Lonestar Masterbash
http://www.mastercraft.com/teamtalk/...ad.php?t=85369
Texas A&M '21
Old 04-21-2017, 04:15 PM
ryancassidy ryancassidy is offline
Boat: 2017 X10
NXTCedarCreek
Mine were under from the factory, but due to the break in requirements it's tough to set the timers until you get 10-20hrs on the boat. The pumps fill at different speeds with the engine off, on, forward idle vs neutral or at a couple MPH's. I'd set them at 10min, vary your RPM's and all per the manual and then once the engine gets broken in, set the timers based on how you will fill. for right now, your bags MIGHT not be fully full. We will fill in Forward Idle. I have 9hrs on mine and plan to finalize the timers closer to 20hrs to make sure she is broken in properly.
HTH's.
Old 04-21-2017, 04:44 PM
SS LS1's Avatar
SS LS1 SS LS1 is offline
Boat: '13 X2 Pro Gen2, '98 30th Anniv PS190- SOLD-
If like our boat once the timers are done, and the ballast is not full, you can press the separate overide fill ballast switches and it adds another 30 sec fill then turns off again. You can do this until there is water flowing from the overflow vents then add that time to your settings.
