Old 05-30-2018, 10:38 AM
Bob B Bob B is offline
Boat: 197 ProStar 2002
303 to water proof boat cover
I used 303 High Tech Marine Fabric Guard on my boat cover and it didnít work. Any ideas on why?
BobB
Old 05-30-2018, 11:09 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
How much did you use? Did you wash and dry the cover prior to applying it?
I did a cover years ago with good results. First, I took the cover to a laundromat and washed it (no soap with a double spin cycle in one of those big, industrial-sized washing machines. I brought it back to the house and draped it over several chairs to dry in the sun.
When it was dry, I filled up a deck sprayer with 303 fabric guard and soaked it. I let it dry outdoors for the next 24 hours or so. Beaded off water like new after all was said and done.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 05-30-2018, 11:48 AM
maniacmikes's Avatar
maniacmikes maniacmikes is offline
Boat: 2014 x-30, 6.2, gen2
Is the 303 a waterproofer? I use it on my bimini top in hopes it will keep it from fading.
This year with my boat cover I took it down to the laundry mat and put it in the big washer. I used "Tech" wash and waterproof from Nikwax that you can get at cabellas or walmart. It is made for washing high tech fabrics like soft shell jackets and sleeping bags, etc. Wash it like normal with the wash, then add the waterproofer and let it soak - rinse - and let dry in the sun. I am super happy with the results - cover is clean and water runs right off it. Best results I have ever had with the cover.
http://www.nikwax.com/en-us/products...?productid=677
The question is not whether life exists after death, but whether you were alive before death - Osho
Old 05-30-2018, 12:32 PM
kwoody51 kwoody51 is offline
Boat: '08 X14
Cover needs to be ‘clean’ and then after you spray cover/ fabric guard needs heat to bond/ volitiles to evaporate.
The stuff works amazingly well but if cover isn’t clean the water will wash off the waterproof dirt and then cover will leak.
Last issue is if the cover is on it’s last legs and is getting a little thin.
Old 05-30-2018, 12:53 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is online now
Boat: 2003 X-Series MCX
Agreed with Woody. I used it on my cover and it was awesome. Cover must be clean and you have to apply the spray to the point of rejection. Meaning, it should be running off. Took me just under a gallon to do my cover and Bimini.
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 05-30-2018, 01:06 PM
I used a gallon, but i did not wash the cover. it it used just to cover my boat when it is on a lift
Old 05-30-2018, 06:59 PM
ryan_kc13 ryan_kc13 is offline
Boat: x30
Which is better 303 or the star brite?
https://www.amazon.ca/dp/B0000AY4RE/...ing=UTF8&psc=1
Old 05-30-2018, 09:29 PM
Infinitysurf Infinitysurf is offline
Boat: 2014 SV244 w/ ZR409
I have used both with similar results. Used the 303 last year and the Starbrite this Spring. Both seem to work about the same with the Starbrite being cheaper
