  #401
Old 07-31-2017, 06:51 PM
MLA MLA is online now
Boat: pontoon
The purple goes to the run post on the ignition. When it is on run, the relay fails closed and both batteries get a charge. When the ignition switch goes to off or accessory, it fails open, only components drawing from the accessory battery from what you have wired to it (should be most everything), leaving your start battery isolated and fully charged.
For anyone following along, an AUTO Combining Relay like the Bluesea 7610 ACR, does this automatically, without the need of a 12V trigger from the ignition switch RUN terminal. Keep it simple.
Im hoping that purple is connected to the CRANK terminal so to engage the starter-isolation mode.
Old 08-01-2017, 04:38 PM
DisguisedRope's Avatar
DisguisedRope DisguisedRope is offline
Boat: 2008 X-2 MCX
Originally Posted by hairman2112 View Post
What is the golf tee for?
Every time he posts that picture someone asks that question. I've yet to see an answer though haha.
~Insert clever signature here~
Old 08-01-2017, 04:58 PM
Reading is a wonderful thing....haha
==> Tee <==
John 14:6
Old 08-01-2017, 05:23 PM
Boat: 2008 X-2 MCX
==> Tee <==
Sorry, missed that one.
Old 08-01-2017, 05:26 PM
It's all good..
There you have it....
John 14:6
Old 08-01-2017, 07:11 PM
TyTanium's Avatar
TyTanium TyTanium is offline
Boat: 2017 X20
Originally Posted by jamis0n View Post
Having each positive battery terminal fused seems like a no brainer to me and definitely will help me sleep at night without having boat on fire nightmares
By having that large of a fuse at the battery positive terminal, the only thing your really protecting the wire from is a dead short.....which is highly unlikely. Remember....downstream, each accessory is fused so if there's a fault with that accessory, that fuse blows and the accessory is isolated (without losing the entire electrical system).
If your trying to protect the entire system from drawing too many amps during normal operation:
If you have too many accessories on the system and draw more amps than the alternator can supply, the alternator just won't be able to keep the battery charged and system voltage could drop. (still no fire though).
If you have a fault in the alternator causing it to supply too much current, it will blow the fuse (or fuse link) on the alternator output wire thereby isolating the alternator. (assuming it has a fuse).
If your trying to protect the starter wire during starting, that's different. I would look at the starter wire size and length and make sure it has enough amp capacity. If it doesn't, replace it with one that does. Don't rely on the fuse to protect the wire.
Old 05-28-2018, 09:59 AM
handleandrew's Avatar
handleandrew handleandrew is offline
Boat: 2003 X9 w/MCX
Excellent info. Thank you!!!
[email protected]@36mph. Hopin' to someday ski w/ the big boys... :-/
Old 06-26-2018, 10:47 AM
Tonytoaster Tonytoaster is offline
Boat: Malibu sun setter 1995 350 v8
Great thread man appreciate it much, for some reason the pictures you posted in the thread will not open for me. Do you know why ?
Old 07-21-2018, 10:31 AM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 07 X2, again!
I have a dual battery setup in my X2. Sterero is hooked up to battery 1. However battery 1 will not charge. So when it gets too low, the stereo won't play, even if I switch to 'All' or both batteries. What could be the problem?
Old 07-21-2018, 11:35 AM
Boat: pontoon
Sounds like the VSR has failed or has be inadvertently disabled. Another though is that the ground link between the two banks is not connected. This electrically makes one back off the grid from the charging system.
A basic hand held volt/ohm meter will help to determine when the alternator charge is stopping and not reaching both banks.
amp, ballast, batteries, stereo, system
